Spark Knock @ "high" RPM
Audio Man
I've had the truck now for a few months and it idles a little bit rough but nothing outrageous. Seems to idle rougher after I've driven it at highway speeds for 20 minutes or so. Just throwing that in so all noticeable issues are noted.
The big thing I'm concerned about is that it gets some nasty spark knock in 3rd gear under hard acceleration. It doesn't do it in 1st or 2nd...solid acceleration with full 15lbs of boost. As an example, getting on the freeway I can hit it and it takes off hard, shifts solid all through 3rd but when it hits 3rd and gets to 4000rpm or there about I hear spark knock. Of course I let off immediately and the truck runs fine otherwise. I did try running a can of Seafoam through it to clear out any deposits, it has new plugs/wires/distributor/etc., I have tried using some Lucas Oil Octane Boost and also the NOS octane boost with no improvement. It does have some kind of bypass for the turbo boost controller to make it controlled manually and the hoses are ok as is the little knob to turn that would increase the boost. It is completely closed and I haven't messed with it at all. Max boost is 15lbs according to the aftermarket boost gauge, not the stock one so I have no reason to believe it is leaking which I assume would add to the boost level.
Could this be a leaking intake manifold or is it something else. It does also have an adjustable fuel pressure regulator so I assume I could add more fuel but it has no gauge on it to see what is happening. I haven't touched anything since I bought the truck, just changed the fluids to Mobile 1 synthetic.
I have a laptop with Datamaster TTS on it but I don't know how to save data on it. Just real time data. It didn't show any codes pending or anything when I ran it though.
I did do a search but spark knock problems listed seemed at all boost levels and even at low boost which is not a problem I seem to have. Only at max boost (15lbs.) and high RPM.
Any help would be appreciated. I am still a newb with this truck. If it was an LS1 this wouldn't be an issue.
Thanks!!
Quickstop [UK]
Combating adversyty.
Re: Spark Knock @ "high" RPM
Sounds like maybe your intercooler is getting hot and then the intake charge is too hot. Higher RPM will have more spark advance so more prone to knock with a hotter intake charge.
Is the IC warm/hot after a run? If so, put a paperclip in the ALDL and connect the two upper right terminals and turn the key but don't start it. You should hear the pump running at the front of the truck just above the lower intercooler.
Let us know what you find.
Quickstop [UK]
What is your fuel pump like? Maybe that's getting blocked and you're going lean. Have you got a fuel pressure gauge or a way of checking it?
Have you got a wideband AFR on it?
Datamaster will tell you a lot though.
Good luck.
If you can hear it, that is really bad. It means the ECM has already taken all the timing it can out.
Audio Man
Unfortunately no wideband AF on it. I need to get that gauge in there which requires another bung welded into the downpipe??
I did go out a minute ago and it is getting no spark retard...staying pretty much at 0 with maybe 3* of retard at full throttle and right back to 0 again. That being said, spark knock count was huge.800+.
Again...pulled strong through the gears and got the spark knock at high RPM.
The intercooler is the stock piece and is hotwired to run full time when the truck is on per the free mods listed. I did not do this the truck came that way. I did check it and coolant was a little low in it so I did add some with the truck running to try and keep out any air bubbles. The intercooler is still warm/hot though after driving it. I am beginning to suspect something is up with the stock intercooler although it is functioning as far as I can hear the motor spinning when I turn the key and the coolant that was in there although slightly low, was clean and looked pretty fresh. What do you think of water wetter?? Would this be a better alternative to the coolant in there or add to existing coolant?
As for the Datamaster, it needs a new key apparently for a new vehicle? I purchased the laptop loaded with Datamaster from a member here. Very happy with the purchase as it does give me alot of info, I just don't know what all of it means yet but I am learning.
The fuel pump is an aftermarket Walbro upgraded pump. It should be fine..again upgraded by previous owner. No gauge on the fuel pressure regulator or way of measuring fuel pressure. This is why I don't want to increase that without knowing current pressure. I can get another one if you think that would be a decent upgrade plus a way to diagnose fuel pressure isn't a bad thing.
Sending you a PM WyoSyclone. Thanks!!
Quickstop [UK]
You need DM running. Is your knock sensor working? Get DM running and then hit the sensor with a spanner and see if it registers. No idea about the code for a new vehicle though :Dunno:
If it's dead it won't pull any timing but that may not be the issue.
Fuel, heat and timing will give you knock.
Can you pull a sparkplug? Take a pic and share it here - some of the more experienced guys can tell you what might be up.
Thankfully it's at higher rpm so you can avoid it for now which you need to do until you have some DM runs.
You should check your fuel pressure - get a line onto the rail and see if it is good. If your AFPR is done then maybe your fuel pressure is too low (too high can also cause knock).
Be careful, you're driving a bomb around with that knock...
Water wetter is an incremental gain I think. If your IC is still hot then perhaps it isn't working as it should. What are your intake air temps? IATs? Again, DM will tell you.
Audio Man
Found several things after doing a complete tune up on the truck.
First off I wrecked it and had it fixed. It wasn't bad but the waste gate actuator took a hit and bent the arm and mount so I replaced it with another but I think the waste gate itself, not the waste gate actuator arm, is either bent or damaged now because with the vacuum line completely removed it makes only 17lbs of boost or right about there. My truck was not using the boost solenoid but instead an adjustable boost valve basically that you screwed open or closed to adjust the amount of vacuum. With it wide open it made about 12lbs. Closed it made 8lbs. Took the adjustor off completely it made 17lbs. so I think it is the waste gate itself that is allowing boost through the to exhaust. The actuator is adjusted corrected and preloaded. This was through an aftermarket boost gauge, not the stock gauge.
Back to the original question. At stock 14.8-15lbs I was getting spark knock. I still am now at WOT, but not part throttle or before 3rd gear. So when it is accelerating and shifting, it gets very little or no spark knock. Not until it gets to 3rd and winds out is when it starts.
I have put a solid tune up on it using ALL AC Delco OE parts. Cap (previously MSD0, plugs (previously UR5 NGK), rotor, wires (previously Taylor 8mm), ignition module (previously MSD), ignition control module with new grease. All replaced...gapped plugs to .28 instead of the stock .35 as recommended in the forums here. Smoothed out the idle as it did flutter alot, still has some flutter. Still getting spark knock at WOT. The only 2 things I can think of is timing and fuel. Has an adjustable fuel pressure regulator with no pressure gauge to go by, might swap that out for one that does.
I still have to check the timing again to be sure it is set at 0 degrees but have a suspicion that it is not at 0. the reason is that the previous owner said he ran race gas through it at 20+lbs of boost so I am thinking he may have advanced the timing to take advantage of the higher octane fuel. Didn't ask him and it has been a few years. If he did advance the timing and I am stock now with everything, then that might explain my spark knock issue right?
Thanks guys!!
johne30m3
Junior Member
Thanks guys!!
Try re setting the timing and see what it does.
