Spark Plug Anti Seize Lub??
RARE_TY
Dose anybody use or recommend using something like Anti-Seize inside the Rubber Boot before connecting it to the sparkplugs? I got the Black Beauty wires and was wonderning if I should use this or some other form of a spark plug boot lubricant.
Thanks!!
Ian Turgeon
Cascading Inspiration
what he said... In fact, the wire manufacturer usually will supply a little tube of dielectric grease for you to use.
Lynn D. Brown
Anti Sieze
Anti Sieze
I would only use the Antisieze on spark plug threads when I was going into Aluminum Heads. And even then, a very thin amount. Remember, the spark plug connection to the head, thru the threads, is the electrical ground for the Spark Plug circuit.
