It's just a six
Super Member
Just curious if anyone here has had a knock retard issue & changed there plugs to a colder heat range & the knocking went away?..Or got less knock retard?
gjp said:I will be trying that this weekend. Right now I have a max of 6 deg of knock. I have ngk ur5's. I was told ngk ur6's were colder. I will change them out and see.
gjp said:I went to do it and noticed One plug looked bad. They are all new but one had a crack on it and I did not want to install. I ordered one because I cant find anyone who stocks the ur6's. I did do a few runs in my truck with the 5's. I am seeing about 7 deg of KR at 10lbs of boost. Fore some reason my truck is only making 10lbs even though my greedy guage says 16lbs. Just something else to try.. I also will try some 100 oct gas too to see if my Kr goes down. Its 4.80$ for the 100 so I will add 10 gallons to a 1/4 tank. Also picked up a set of taylor wires.
