Spark Plug Problem
rhaley
Hello group, I have had an ongoing problem since I had my engine built. The problem is spark plugs, I have tried Delco R43LTS, R42LTS, NGK TR5 & TR6, and Autolite 104 and they all run great until I hit 15# boost. At 15# and higher the engine cuts out and I get a lot of backfiring. Every time I put in new plugs, it will run good for about 1 week. I started gapping at .035, then went to .032, and finally .028 which is where it ran great on Autolite 104's for about 2 months. This weekend I installed a new set of Autolite
104's that have lasted the longest, only I gapped them at .032. This morning I got on it and all it did was backfire under higher boost. I have used 4 different coils, 6 different sets of plug wires, and many Conrad
rotors & caps but it will only run right with new plugs. At this point I totally believe it is a plug problem, what is every ones experience with plugs and gaps? Next I will try gapping at .020, this seems very tight but the tighter I gap, the better it runs.
My engine is very modified so I am not looking for stock applications or settings. Here is a partial list of my mods:
8.35:1 compression
Ross forged pistons
McCoy Vortech heads with manifold port matching
Garrett TE62
50# injectors
Big cam
Speedpro engine management system
Detonation is not a problem.
When I am running right and hit the throttle at a 20 mph roll, it will slide sideways and it is still pulling strong at 6000 rpm. It builds boost with what seems like no turbo lag, it is at 20# immediately.
I guess what I am trying to say is it runs great with new plugs and a tight gap. But why?
With the old engine, I ran the TE62, 40# injectors, stock heads, stock pistons and stock cam at 20# and never had a problem.
Any help would be greatly appreciated,
Ron Haley
Sandy, Utah
smeagol
How do the old plugs look when you pull them?
Any inconsistencies from cylinder to cylinder?
I always ran my Syclone with .032-.034 with Autolite 104s, no problems with higher boost unless I used Rapidfires.
rhaley
Brian, I believe we have discussed this before. They are always white with no difference from plug to plug. There seems to be white film on them that looks like very thin white paint and there is no fly poop. If you wouldn't mind, I can send you some Speedpro runs to look at when it is running right. I have a feeling I should go colder and tighten the gap.
