Hello group, I have had an ongoing problem since I had my engine built. The problem is spark plugs, I have tried Delco R43LTS, R42LTS, NGK TR5 & TR6, and Autolite 104 and they all run great until I hit 15# boost. At 15# and higher the engine cuts out and I get a lot of backfiring. Every time I put in new plugs, it will run good for about 1 week. I started gapping at .035, then went to .032, and finally .028 which is where it ran great on Autolite 104's for about 2 months. This weekend I installed a new set of Autolite
104's that have lasted the longest, only I gapped them at .032. This morning I got on it and all it did was backfire under higher boost. I have used 4 different coils, 6 different sets of plug wires, and many Conrad
rotors & caps but it will only run right with new plugs. At this point I totally believe it is a plug problem, what is every ones experience with plugs and gaps? Next I will try gapping at .020, this seems very tight but the tighter I gap, the better it runs.
My engine is very modified so I am not looking for stock applications or settings. Here is a partial list of my mods:
8.35:1 compression
Ross forged pistons
McCoy Vortech heads with manifold port matching
Garrett TE62
50# injectors
Big cam
Speedpro engine management system
Detonation is not a problem.
When I am running right and hit the throttle at a 20 mph roll, it will slide sideways and it is still pulling strong at 6000 rpm. It builds boost with what seems like no turbo lag, it is at 20# immediately.
I guess what I am trying to say is it runs great with new plugs and a tight gap. But why?
With the old engine, I ran the TE62, 40# injectors, stock heads, stock pistons and stock cam at 20# and never had a problem.
Any help would be greatly appreciated,
Ron Haley
Sandy, Utah
8.35:1 compression
Ross forged pistons
Garrett TE62
50# injectors
Big cam
Ron Haley
Sandy, Utah
