spark plugs and wires
vinnieTy
TY # 1889
I am looking to change my plugs and wires and it seems that doing a search gives me a few posts with what people are using but not on what they recommend. I dont mind going with a better plug then stock and maybe thicker wires. What are your recommendations??
thanks
Bill Z
Re: spark plugs and wires
Are you running a stock ignition or MSD or Mallory....? It makes a dif.
SYO237
SyTy Registry
I recommend
Taylor Spiro Pro wires, 8mm (Tucker Auto Parts)
NGK UR6 plugs or AC Delco CR42TS (if you dont drive hard all the time)
Not sure what took the place of Conrad, but get a cap/rotor with brass. Better conductivity and longevity.
cloneman315
ngk ur6 and magnacore wires i think are best.little pricey have had my wires for 3 years not a problem
syclonekid43
ur6 plugs work alot better than a/c's in my syclone. im running a set of accell extreme heat 9000 wires. they stand the heat real good. i had one touching my downpipe and didnt even leave a mark on the wire.
danny
for a stock truck you should use ur6's? why are some people using ur5's?
syclonekid43
i ran ur5's once cause i could not rember which ones were the right number. they works good in my truck.
gjp
another post whore
I was told ur5's. whats the difference? heat range??
sy#2921
BAMF
ur6's are one heat range colder than ur5's. NGK rates the ur5's as stock heat range. I would say myself if everything is stock then run the 5's. I agree with the taylor wires i run them on everything i own that has wires and never had a single problem
