Spark Plugs on Vortechs, again
Lynn D. Brown
Hey Vortech Gurus,
I had copied the Vortec Spark Plug discussion on Tech talk on 09/02/02, but couldn't bring it up w search.
I'm a little confused - which is Normal. BG mentioned Autolite 103 plugs and AC R42TS, but I think he must have meant 42LTS, or the longer reach plug. There is about a 3/16" diff. in tip length, which is a mile.
So, do we need the longer reach plug on the Vortechs ? If so, then for the moment I guess I will go w the AL 103's, which I need for my GN Alum heads anyway. May try the Iridiums later.
That means I've got alot of the stocker CR42TS plugs that I can sell someone. Anyone interested, let me know - I'll let them go for $1.80 apiece plus shipping. Must have 2-3 dozen.
Or, I could bring them to the Nats. Guess I could put it on Buy/Sell Forum
smeagol
the 42LTS is correct, thanks
Autolite 103's work
i'd use the NGK TR5 or TR55 or TR6, but that's just me
Tony ran the TR6's
Gavic has been using TR6
McCoy was using some Autolites, not sure what nowadays
LS1 guys use TR5/55/6's nearly exclusively, for NA/Nitrous/boost
Lynn D. Brown
vortech makes superchargers, not heads...
Thanx 4 pointing out that subtle - at least 4 me - difference. I hadn't really noticed that till now.
Sy769
Autolite 103's work
Tony ran the TR6's
Any comment on the differences in the various NGK's BG mentioned and the Autolites
TurboTony
I'm actually running the TR5's now.
We found that the TR6's would foul to easily when running straight c-16 at the track.
From what I was told the TR5's equal the same heat range as a 42, the 6's are one step colder.
I also have a few sets of the denso iridiums to try. Just haven't had a chance yet. I'm expecting good things from the denso's based on what I've heard and seen on some really high compression two stroke stuff that ran here this winter.
Tony
GEN3Typhoon
ok... so let me get this right...
I have the Vortecs on my car... I am running the stock CR42TS plugs.. and these are not the ones that I should be running?
Please clarify... I am having an off idle stumble that I cannot get rid of.. and I am wondering if this has something to do with it...
Shit... wondering now.
NGK TR5?
AC 42LTS?
Lynn D. Brown
Nick,
I'm glad I put this Q in the Forum - looks like we both learned something. I went thru the same thing on my GN. Wouldn't run for S on the stock plugs in the Champion Al heads, and then Conley told me to switch to AL-103's. It was a big improvement.
sytyguy
Moderated User
Plugs again, eh? Here goes:
LB4s/L35s
AC Delco - CR42TS
NGK - UR5 (stock heat range)
NGK - UR6 (one step colder)
Autolite - 23
Vortecs
AC Delco - R42LTS
NGK - TR5 (stock heat range)
NGK - TR55 (one step colder)
NGK - TR6 (coldest)
Autolite - 764 (comparable to TR5)
Autolite - 605 (comparable to TR55)
Autolite - 103 (comparable to TR6)
The Autolites are available in a racing series (ARXXX where XXX is the stock number....103, 764, etc....). These racing series plugs have a larger ground electrode as well as anti-corrosion nickel plating (similar to an AC Delco R vs CR). NGK also carries platinum, iridium, burilium, plutonium, kryptonite, etc.....plugs, just put the appropriate suffix after the number (IX for iridium & VX for platinum - TR6IX, etc....).
Hope this covers it all. If you want Champion plug numbers, they better be for a lawnmower. :wink:
Hood
100in6
100in6
for what it's worth and for those interested, I ran autolite 104 when I ran the 10.43. chanaged em today to 103's and also bought a set of tr6's to try. I only ran 110 octane, but if I get approved for the bank loan I would like to give the c16 a try. jujst hate having to buy 13 gallons of it cause this damn stock tank design sucks. anyone given the sunoco maximol 116 a try?
Lynn D. Brown
I guess U R talking about a Sy ? Don't think the Ty's have that gas tank problem - at least my '93 doesn't.
jwaller
Evil Genius/SyTy Guru
I most definalty have this problem. if you start going fast enough you will too. I have to run at least 3/4 tank of gas to keep from having fuel slosh problems....
GEN3Typhoon
Well I put the TR5 plugs in the truck... and guess what... NO MORE STUMBLE. Now I have some more tuning to do.. but this morning I drove it to work and no more stumble.
I am so glad this information is here.... thanks to the question askers. Learn something new everyday.
bezerk
okay so i bought me Some NGK TR5's for the job..
the only thing i was wondering, iám going to install the engine tomorrow, and it would be great if i have the sparks already in there before the drop..
stock no. 7873 is this correct??
thanks
bezerk
i have seen the that post, but the the guy who sold them to me gave me tr5 with the #7873 on it, like are there other TR5's out there, that have a shaft that is to long for our app.?
