Spark plugs
White97SVT
I heard there are a couple of different how to's on them...I was wonder where i could find them. I looked in the vault here, and on the archive how to's.
I was wondering if anyone has written a how to, on how to change the plugs. like take the inner fenderwell out and the easiest way to get to the plugs.
I remember seeing somewhere that there was an easy way to do it, with out taking out the fenderwells. There was like a do your plugs in 10 mins or something like that.
Thanks for the help guys, I am trying to get the truck all ready for spring.
Zac
You don't need to pull out the fenderwell's. There is a flap at the back of the fenderwell that you can lift up to get access to the plugs. Just jack up the front of the truck. Removing the wheels makes things that much easier. Make sure that you get one of the plug socket's with the swivel end from Sear's. It will make getting the plugs out that a breeze.
InvisiBill
http://www.syty.org/old/clean.html#Maint
I too do it through the wheelwell without removing anything, including the wheels. I've even done it from above on the S-10 before, though I'm pretty sure it'd be impossible with ABS, A/C, and all the turbo stuff in there. You pretty much need one of the swivel spark plug sockets to get at #3, which is right behind the steering shaft. Other than that, I just use a ratchet and a couple extensions.
It'll take longer than 10 minutes, but it'll get faster the more you do it. I always seem to have a problem with one plug, then it just pops right out after I give up and do the others first. *shrug*
Make sure you use the right plugs as well. AC CR42TS (not CR43TS, not R42TS) and NGK UR5 seem to be the best. UR6 is one step colder, and the Iridiums (-IX) are supposed to be good, but they're quite expensive.
Sy769
The wheelwells are easy to pull. 10 bolts or so,with airtools it goes really fast. You can then see everything and make sure wires aren't chaffing or touching anything hot.
White97SVT
Thanks for all the help in answering the question for me...the truck will get a fresh set of plugs and fuel filter and a few other things come the start of spring and be ready for a new season....Thanks again
