Spark Reference Angle
crashing_sux
Blow Me?
I'm experiencing quite a bit of knock. I've read a zillion threads on diagnosing it so I'm not looking for any help there (yet). One of the steps many people say to take is to use higher octane gas which costs too damn much money for me or to reduce timing. If I find my knock is real I'll take the appropriate steps but just for the purposes of finding out if this is false knock or not I was thinking the easiest method since I have an emulator would be to just pull some timing.
Can I just set a negative value in the Spark Reference Angle constant? Or should I pull advance from the spark vs. rpm vs. map table?
skwayb
NWSTP
Re: Spark Reference Angle
You need to pull it from the spark vs. rpm vs. map table. Yes that means you have to update each cell. (i.e. if you want to take 3 degress out, you need to subtract 3 from each cell.)
If you have the newest version of TunerPro RT, you can just select all the cells you want, click on the toolbox button and there you can add/subtract/multiply/divide to all the cells you have selected. Put in the value you want subtract and hit execute. Pretty simple.
crashing_sux
Blow Me?
I'm using tunerpro, which luckily works great for that. I wish it worked as well for ALDL. Either it or the moates drivers are crap because it hangs about half the time I try to connect on the aldl port, and nothing will free it up. I can't even end the task in task manager, I have to reboot.
Even when it works, it only connects once every three or four tries. Oh well, damn good product for the price.
