Spark retarding back to zero.
The Bronze
Decided to open up a thread for this rig.
My buddy just traded up to a Syclone. It was my first time driving one, since my stuff is in paint purgatory. He threw me the keys, said to pay attention to the harsh shifting and walked away.
To say the shifting was harsh was an understatement. First gear shift is severe. I am driving this vehicle, thinking about how hard it is to see the speedo behind the aftermarket steering wheel and I begin to accelerate up the onramp. At half throttle it is pinging and is slow to disappear (and accelerate). I decided I needed to test drive this to my house and grab my laptop. I did two rather easy pulls, especially until the detonation quieted down. There was no need to push it any harder, so I saved the file and babied it back to his work.
I took a quick look at the datalog and told him to stay off the throttle until we could take a look at it. Here's the log.
http://www.mediafire.com/?gu23qzprprkrf
I don't see anything too amiss outside of the large amount of spark retard. The detonation is real, so timing is at the top of the list. The vehicle is still "rich" on the NB. While the truck came with an aftermarket chip, but the stock chip is supposed to installed at this time. It has a very low mileage stock syclone motor installed. Time for a tune-up and timing adjustment. He ordered up the tune-up parts. Kinda curious if it really was a syclone motor or a standard 4.3L that was reinstalled.
I am going to get this back in a few days and do some work on it. Unfortunately, I won't be able to use the in-cylinder pressure transducer since mine is set-up for a vortec. Maybe I can get him to cough up the $$$ to buy the stock plug set-up. I would be cool to see the waveform with that much detonation occuring!
Re: Spark retarding back to zero.
Well my :2cents: is to propperly set advance (wire disconnected). Correctly set trans cable (should fix hard shifting). The test drive and see where it went. May have to check TDC. :2cents:
WyoSyclone
I'll take a look tonight when I get out to the shop.
EDIT: Holy KR batman! Wow, stay out of the throttle till you look at things. Check all the vacuum lines, check base timing. Ask your buddy what kind of gas he's using. Pull the plugs and see how bad they are as well as the cap and plug wires.
Looking at how the boost bleeds off I'd say you have a pretty good vacuum line leak which would affect your map. Look there first.
KBowman
I did not look at your data file because I do not have datamaster loaded on anything now but it will have a very audible knock (pinging) if the intercooler is not bleeded of air. What are the intake air temps?
