Speed Pro (FAST system) questions..
myclone
Ive been kicking the idea around for over 6 months of going with an aftermarket EFI on myclone and have a few questions if someone could take the time to drop some info in my lap.
Keep in mind that its not gonna happen right now as Im just looking at the pros and cons of doing this..
Questions pertaining to Speed Pro bank to bank:
Can this thing control the TC lockup (poss using the N2O or cooling fan outputs)?
Can a puter moron such as myself get a handle on the software?
Can it be integrated into the factory harness for the injectors without hacking the harness up?
Is there any data logging feature on the software that comes with it or do you have to purchase seperate software to do this?
Can you monitor things like KR, RPM, boost, etc in real time?
Lastly, how bout the sequential(sp?) system? I don think I'll need it to reach my goal in performance but if it is only a few dollars more and not much grief to make it work is it worth it??
I dont really need it the system to reach my perf goals but I like to be able to tinker around with the fuel/timing without the hassle of burning chips, re-teaching myself hex, or bothering ppl across the country that have better things to do when I wanna change something.
Facts/figures/opinions are more than welcome if you dont mind taking the time to respond..
As always... TIA.
4C FED
Absolutum Dominium
NO, you'll have to find an alternative.
New harness included to plug into old ECM harness.
You also have a new injector harness.
You'll have to run a crank trigger for it to work, from what I understand.
smeagol
* No TC Lockup. You may sacrifice IAC control for NOS. From what I've been told, the fan should work. Mike Lee's didn't but he has a special oddfire system.
* Yes, very easy to catch onto if you have a clue about how a motor works.
* No hacking needed whatsoever. PTE has the plug n play harness. You have to run a new set of wires thru the firewall, as it requires a new injector harness (peak n hold injectors don't have common wire like saturated stockers), as well as a new 02 harness (wideband 02 sensor has 5 wires versus 3 for stocker).
* Comes with it. The DOS based stuff has some limitations to amount of datalogging and framerate, but the Windows software is much more capable.
* Yes, this makes for the best tuning. If you are in the VE table, you see a bubble floating around the values that are being accessed at that point.
* I see no need for it, Buicks have run up to 96# injectors without it, and have ran fine.
* If you want easy tuning, and are planning on changing a lot, and you don't flinch at the price, I say do it.
Keep in mind you need to get the TC lockup controlled, so that is an extra $200 you can spend on the B&M kit.
Other options : Wait for the DFI v7, which has TC lockup control, and some nice features. I can't vouch for it, as well as the fact that there are many people running Speedpro/FAST who are happy with it. You won't have the support of tons of people using it (not yet at least) either. AEM is offering a trick looking new setup, but again, you don't have the millions of people supporting it yet either. Me, I'd have no problem starting out a system from scratch and creating my own calibration, but others do....
myclone
Thanks for the info ppl.. Much appreciated. Keep it coming.
Few things (immagine that):
The lack of TCC output on the speed pro BITES but Im an electronic tech so making my own thingy wont be a big deal. As long as it can be done with analog components Im fine. Get digital then Im screwed....
I think a bank to bank would more than take care of me. Im not after 9 sec 1/4 mi times (be nice though) but I would like to tinker around with diff cams/heads/valves/rocker ratios/timing/fueling/etc. Just goin for 12 flat as far as perf goals (hight 11s would make me happy too). I just wanna be able to experiment without having to bother ppl that are already busy..
Brian,
Do you have a site/addy for this DFI v7 stuff? Id like to look at it. How does it compare in price to the speed pro?
Converting to a stand alone system wont happen till poss this fall/winter so Im in no rush. Just kinda gathering info to decide what I want/dont want.
Thanks again..
SPiN
You might also want to check out the New Accel DFI 7.0
Has TC control and form what I hear is VERY nice. For sequential you have to run a crank trigger setup but a plus to going Accel is that the oddfire for our setup is just a couple hundred dollars more than the standard setup compared with Fasts' approx $1000.
You must also purchase the wide band 02 for accel which I think was 220.
I am running FAST sequential setup but I think I might have considered Accel now that is is becoming more available. I am going to be able to check out a live system in a week or two. Ill try and post about it.
smeagol
From what I heard, DFI wasn't going to support any oddfire stuff. For most companies, it's just a PITA. In the past, Accel just had a special ECU for oddfire that had no timing control.
Has an Accel rep told you it would work for oddfire? Sequential or not isn't the issue, controlling an oddfire's ignition is. Would it do coil on plug or wastespark ignition for the oddfire? What kinda pricing are they quoting? With what options? Is anyone doing harnesses for them yet? DFI looks pretty trick, I just haven't heard of anyone running it really.
The AEM stuff looks amazing, but you'd have to spend LOTS and LOTS of time to get the system setup how you want it IMO.
