speed pro & gm ecm coexistance
nightdiver
what if i power the stock ecm
connect the sensors needed
will this make the tcc ,air condition,cc,work ?
the buick guys did !
smeagol
You could make it work, but you'd probably need a custom chip to disable some codes etc.
Could work, just might be some extra labor..
nightdiver
Damn
that was fast !!!!!!!!!!!!!!!!!!
so ill have a check engine light no problem
do i need to feed the ecm with the 2 bar map sensor ?
4C FED
Absolutum Dominium
There is someone in CA that has a special harness with some magic added that fools the ECM into thinking it is hooked up correctly, when in fact it's not doing a thing.
That way when you smog it, everything looks cool even though it's running FAST.
I was quoted $500 for this harness.
I figured I'd use a Hobb's switch to control the Check Engine light and save a lot of money.
nightdiver
i killed the check engine ligth from the chip.
now im looking at the shematics at the manual to find all the wires needed for a proper function
i have to give it a try
if it fail ill go to b&m for the tcc
the air cond. will work with the wire grounded
i find no reason for the cc not to work
Man and i didnt even receive the speed pro that i ordered
ttt
