speed pro tuning ?'s
Pittman
First one
if sitting at an idle and I nail it. It will stumble for an instant and then tear ass. Is this AE Vs TPS rate of change
Second
My target AF and actual AF are 11.6 at WOT they are tuned dead on. However after the initial stab of the throttle AF will go rich. Is this a function of AE vs TPS rate of change or AE vs MAP rate of change
4C FED
Absolutum Dominium
You might want to search the Turbo Buick UBB in the Performance ECM forum.
I know the FAST guys provide lots of help with these kind of ?'s.
First one sounds right, however if the VE values are far apart, say 10 or so, it might stumble from that. The FAST averages the numbers from the cells that the "bubble" is touching. I guess it doesn't like big changes in numbers.
The second one sounds like AEv.TPS, however I don't know anything.
smeagol
The AE stuff can be fun to dial in 8)
There is a lot to take into consideration here. First off, tune the VE based on conditions that are relatively static - nothing changing, as far as RPM, throttle, etc. Once you have the VE dialed in how you are confident it should be, then work on AE separately.
With FAST, the TPS adjustment is important, so if you manually change your throttle body setting, your calibration (if it was dialed in already) may get F'd up.
AE fuel vs TPS position is one that is very powerful, and is affected more than others if you adjust your TPS. Basically it is a factor that is multiplied into the AE based on the current TPS. It should be a table that is a sloping downward line, nearly a 45 degree line. If you have your throttle set for low RPM, the factor from that table at SLIGHT throttle opening is very large, 90-95. If you set your throttle blades open a bit, the TPS reading at idle is higher, maybe 15%, and the factor from this table at the same SLIGHT opening will be lower. So your calibration needs to be changed. This is the first table i'd look to for solving weird AE problems.
With AE, it is easy to make a problem seem fixed, but then create other problems. Remember this when tuning. Seat of the pants might feel fine once you make a tweak, but then you may have a crappy AE issue that crops up under other conditions - like 1/2 throttle to 3/4 throttle is lean...
Anyways, you are on the right track. Save old files, try some things, take notes.
Also, with what Christian mentioned... try hard NOT to correct AE problems with VE. There are some situations when you can, and that may be the best workaround to do so, but it's not a good idea. Also, FAST simply doesn't just average the values. It does some serious interpolation, and not just 2 points. Think about this - 4 adjacent cells, that border each other. To give you an idea of the interpolation, take those 4 cells (that form a square), now create a new table, with those values at the corners. Between those corner cells, there are 16 or so cells that are essentially used & interpolated by the ecm. The computer in effect, takes an average, but it's a bit more complicated than just finding the halfway point between 2 bordering cells.
I threw together a webpage to illustrate.
http://www.chitownsyty.com/bg/stupid/interpolate.htm
2 more points-
FAST does this on all graphs/tables..
Stock ECM does this on all graphs/tables..
Pittman
Thanks
I had to print that post off..
That helped me get a better understanding on what its doing.
GEN3Typhoon
It is a funny coincidence...
I am starting this at the same time... I was just messing with this today and was about to post the exact same question. Seems we have the same problem.
Just off idle about 1200-1700 rpm..... a stumble and while logging you feel the stumble and it goes to 15.9 A/F
This gives me a great start... I have been messing with this all day...
So I was following this method.. sounds about like what you described.
I was adjusting VE so that it idles ok... and so at constant throttle it seems fine.. a stumble here and there.
Then once I have that I will start adusting the AE stuff.. so complicated .. I am learning.
In case no one has said it yet.. I appreciate the advice and the help.
TIA
Pittman
I played with mine a little today and have inproved it. I need to do some more loging. My truck is really picking up
Although, Today I had a lifter go out on me ( a crane with less than 2K ) Damn thing sounds pretty bad so looks like im pulling every thing off again this week. :evil:
NO kiddin
Thanks to all
If it wasnt for this board I would have sold my sy long ago.
rarebit
"Just off idle about 1200-1700 rpm..... a stumble and while logging you feel the stumble and it goes to 15.9 A/F"
hmmm....whats your wide band correction doing during this time? i bet the wide band correction is pulling fuel out prior and during the stumble. if thats the case, suspect too much wide band correction causing the stumble.
try this- lean out the ve table underneath the 1200-1700rpm stumble problem. lean the ve table out enough so the wide band makes a positive correction and adds fuel in instead of taking fuel out. now when the engine gets to the stumble point the a/f will be fatter, probably more accurate, and less prone to stumble. you may also try adjusting the wide band correction so it cant take too much fuel out at idle-1700rpm. like around -10%-7% or less.
the computer cannot read and adjust the a/f ratio fast enough to always keep the a/f ratio in check. a lot of times(more often then not) the a/f correction will be wrong. especially when the map and/or the rpm make rapid changes- accel,decel,changing gears, tc lock up, turning the ac off and on, etc...about the only time the a/f correction is accurate is when the engine stays at a constant rpm and map.
make sure you tune under load- in gear, driving around, tc locked up, ac on. once again- dont try to tune ve and ae at the same time. stay focused on one thing. make a change, save each change with a seperate file name, and notice how the change effects the engine. if the engine doesnt like what you did to it, go back to the previous file. try to go back and look at the progress you made with the changes you made. go back and look at the files in sequence. oldest to newest. notice any trends in how the ve, ae, af and timing tables have changed. try to predict what you need to do to get the engine closer into perfect tune.
smeagol
Great post Paul, I've done the exact trick you are talking about - but it's hard to explain it exactly.
You can adjust the gain on the wideband correction to help some of this, but usually I just set the closed loop point to avoid closed loop idle or just off idle - so at light load/cruise it WILL be closed loop though.
That is all my opinion of how to leave it set. If it was up to me, I'd make my own tables & parameters for closed loop... say 35-85mph, with TPS between 10 and 45%.... and also allow for safety at WOT, in case of going lean. Oh well...can't do that with FAST :-?
