I've been having fun getting my newly purchased Ty up and running and legal (passed emissions and registered yesterday!). The one remaining snag is that the speedo either doesn't work at all, bounces erratically, or 1 time out of 10 works fine.
I've done some troubleshooting including checking the blue wire in the DRAC and making sure to stuff it in there... then slamming my hand on top of the dash (funny but true). This combo appeared to get it working for one drive, but it didn't take. The next trip, erratic, then nothing.
Today, I pulled the pin in the drac and soldered the blue wire to the pin, re-inserted the pin. Wallah! the speedo appeared to work perfect.
Unfortunately, the very next time I drove it, the speedo seems dead as a doornail. I pulled the instrument cluster next, and did a cursory inspection, I lightly scratched the connections that appeared to be the same blue wire. The wire behind the cluster seemed ok. I re-installed the cluster, and the speedo still doesn't work.
Any ideas? Do I need to check any other wires at the DRAC or ECM? a ground perhaps? It seems like bad ground or short. I was blaming the cluster, due to a data logger showing the speed is being sent out correctly, but messing with the drac wires appears to have more impact on getting it working. Could the DRAC itself be bad?
Thanks in advance...
Leuds
Leuds
