Splayed Main Cap Bolts and Studs ?
Tydriver
TurboLS6 Powa'
Here's the situation. Tell me your suggestions.
4.3L getting converted to 4 bolt Splayed Mains.
Obviously use ARP 233-5601 studs for the threads that already exist in block
What is everyone using for the new 'Splayed' holes that I am having machined into block ??
I have searched for about an hour on this subject and havent seen any part #'s or anything related saying what to use.
If I order the studs (ARP 233-5601) by my calculations I will be short a total of 4 bolts needed to tie down the center 4 bolt converted mains (2 bolts for each new splayed cap).
Obviously since these holes are splayed I wouldnt be able to just screw studs in correct ? Or can I install the cap on the 2 vertical bolts and then screw in some studs afterwards ? In theory that would work.
I know some of you guys have had to deal with this before what do you recommend ?
What are you using for PART #'s for those extra 4 bolts ? I prefer to use ARP all the way around if I can please.
Methuselah
Todd, one of the reasons I want to call you this week is to discuss the issue of 4 bolt mains on your block.
If you are interested, we can split a third set of ARPs to cover 4 bolting two blocks. Assuming ARP has bolts for mains and not just studs.
Seth.
________
TOYOTA F3R HISTORY
Tydriver
TurboLS6 Powa'
Seth.
Well like I said, you have my phone # !!
LOL, I already have some of the stuff I need, just want to make progress on more of the missing peices. I am not even sure that the studs that are used in the VERTICAL hole will work in the splayed hole. Hence my reason for asking Q's
Did you order the # I gave you?
Did you even open the box?
Freakin Hoosier's, all the same. You would think you were some robot technician or some shizzle.
FYI, my kit came with studs for center bolts, and regular bolts for outside, as be hard to stud them at an angle.
So pull you head from your arse. 4 days off in a row is messing with your brain cells?
Methuselah
Well, that's that then. What kit (w/ part number) are you guys using then?
________
Shemale bondage
jwaller
Evil Genius/SyTy Guru
I use the moroso SBC conversion cap with the 3 center caps splayed.
this leaves you with an extra splayed cap whcih I have milled into a 2 bolt cap and install it into the front location.
the kit comes with 4 allen bolts for the 4 splayed ones. bc you cant put a stud in there from the begining. I suppose you could thread one in afterwards but I've always just used the bolts they sent.
the kit also comes with studs for all mains. which I dont dont know who maked them so I just use an arp kit and toss the others...
arp will sell bolts lose so if it's that big of a deal you can get the dimentions from moroso and order arp's for the splayed ones
Tydriver
TurboLS6 Powa'
:roll: No dumbass, but it appears that you have lost your brain.... Damn engineers they are all the same. And whats with the Hoosier comment ? last I checked you lived in Indiana too, in fact ALOT closer to the land of KY than I do. :wink:
With that said, allow me refresh yer pea-brained memory, I didnt order those studs because they were on back order. Hence no box to receive and no box to open. Typical engineer, always 15 steps ahead of the 1st step when the 1st step hasnt even been started.
LOL, all ya had to do was ask me silly, I told you it wasnt on Summit's page when I ordered the other stuff and it wouldnt come up. Then days later when it finally DID come up, it was listed as a B/O item. Hence my post for asking what other hardware was needed as I was going to order that stuff too :lol:
#1 It is YOUR fault for not trusting an engineer. Especially one that has the parts sitting on his desk.
#2 You can order from more than just Summit.
#3 Hoosier is an Indian term, you have lived in Indiana Longer than me, and you are DEEPER in it. In fact are you not right in the middle of the state? I can escape Indiana within minutes, you have over an hour before you get close.
#4 Your truck will never run.
#5 Who would want to own a baby blue ty anyways.
#6 Anybody following this should know Todd and I are good friends, hence the ration of crap we dish out.
#7 You probably are sitting there all day bored, with nothing to do so you ask stupid question on the board and waste bandwidth.
#8 Do you have a KB.bin for you truck yet?
Tydriver
TurboLS6 Powa'
LOL
smartass....
Can we please get back on topic tho ? I'd like some insight from anyone OTHER THAN an engineer (since they are all the same) :wink:
scotts4
ADDICTED
does anyone use a steel cap for the rear one if so what brand and part #. I ask because my motor was replaced before i got it and i do not know if the caps are the correct ones and would like to use all steel caps :wink:
scotts4
ADDICTED
so if i keep the stock rear cap how do i check if its the sy/ty rear cap?I am going to replace the 3 other ones with 2 4 bolt splade caps and 1 2 bolt steel cap. i just want to tell if i have the right cap. What extra machine work will i need to put the steel cap on the rear? It will not just bolt on like the front one and then line bore it ? thanks for your help
jwaller
ya the rear cap will just bolt on. but you/machinist will have to be extremely areful when setting the rear cap so that when you line bore it the thrust bearing surface as well as the main bearing surface is perfectly lined up.
ghettosled
SYTY SUPERSTORE
i have a brand new stock block that has already been converted if anyone is interested. Has milodon 4 bolt center caps. Has been align bored, and honed.
bezerk
what''s the price on that one??
maybe i''am intrested.
If you look in the gm performance parts book they have some splayed caps and a 2 bolt front cap avaliable you can get all three for less than 150 bucks, and the correct ARP stud kit is the 233-5601, it comes with the studs for the stock holes and the bolts needed for the splayed outer bolts, the new caps will need the block registers machined out and the bolts drille dand tapped and then the mains align bored and honed, and as for the rear cap, pro gram enginnering has the only wet sump 1 piece rear main seal cap on the market and it list for 260, i just ordered one from them, You can check there website, see other ppst, and it is listed as late model V6. It is the same material as the caps in the gm performance parts catalog. Heres a few links.
http://www.gmpartsdirect.com/performance_parts/store/catalog/Product.jhtmlPRODID=663&CATID=660.html front cap 1 required
http://www.gmpartsdirect.com/performance_parts/store/catalog/Product.jhtmlPRODID=662&CATID=660.html center cap 2 required
From Pro-Grams website---SB90V6RWSL 90 V-6 Rear Cap (wet sump with late style block and offset bolt holes) 1 $254.00
Heres the link to all the rear caps they offer
http://pro-gram.com/catalog/catalog...APS&cart_id=5747657.27874&store=program.setup
And if you want to see what the gm caps look like up close, heres a shot of mine, these are on my bowtie block, and didnt need the registers machined out, just bolted right up, and only an align bore and hone as soon as that new rear cap gets here.
http://www.h-a-s-t-e.com/modules.ph...ame=gallery&file=index&include=view_photo.php
Oh, and i just wanted to add that i ordered the main studs from Summit as well and they tok right at a month to get them, cost was like 56 bucks i think, a few places in town couldnt get them at all, even direct would have taken longer. I have a set of head studs that have been on back order for a month already and they are supposed tro be here on friday, so well see. I hope this helps you out, and shop around for a good shop to do the conversion if your not doing it yourself, i called about 5 places local and got a huge difference in price, the cheapest place has the best reputation. They are the ones doing all my machine work.
