Sputtering at 1200-1700 cruising.
Injected1
while my garage is empty due to SYANARA getting the IC piping finished up. Dad asked me to do some work on his TY. Bone stock except for the Borla exhaust, Z06 wheels, and 106K on the odometer.
It would drive great under power but when cruising frome 1200-1700 it would start to sputter out. I assumed it was a vacuum leak since it still had the original lines on it. I did the silicone vacuum line kit and the Egr delete and now the truck Idles like crap and won't accelerate until I pull the vacuum lie off the map sensor. I have tried 3 map sensors from Oreilly's (EC1602 and EC1765) and none have worked. It actually made it worse. Any ideas on what could be causing this? Also is there anything else involved in the EgR delete besides the block off and removing the solenoid and vac lines. Does anyone have a spare 2 bar or know the correct part #?
The truck just had all new plugs, wires, cap and rotor installed 2 months ago so I don't think that is the problem.
