Sputters at low and high boost
milky 1704
026TB4U
I'm fighting this damn thing. I had a sputter or stumble under bost around ten psi. I've changed plugs wires cap and rotor. Done compression check. Now I went and set base timing to zero with wire unhooked it runs worse any help would be great. I wonder if balancer is spun. Truck was running great last year and then the higher boost stumble started
IGottaSy
How long had it been parked since last year?
Have you tried some high octane fuel? What's the fuel pressure doing and set at? What chip / injector? Any modifications? Balancer does have two marks. Make sure you are setting time on the correct one. What was done different from last year after it ran great? Lots of info left out. Describe your truck as much as possible.
IGottaSy
Like crap if it runs at all. So, you don't know your chip / injector combo? Stock fuel pump? New fuel filter? Does your tach needle move when you crank the engine? Need as much information as you can provide. Tons is being left out. Scan tool? Fuel pressure keeps up with boost? 1 for 1, e.i. start at 48 psi fuel pressure and 10 psi boost = 58 psi fuel pressure. You should be set at 43 psi hose off.
IGottaSy
Also, you need to let the ECU populate the cells after each time you disconnect the battery as it lost what was in memory. Drive it around for a good 15-20 minutes.
milky 1704
026TB4U
Stock ecu and injectors. After i set the timing I shut truck off I didn't disconnect battery. Stock fuel pump and yes new filter.i don't have a scan tool I will use one this weekend. I will check tach in the morning
IGottaSy
Check the plug wires order. Asked how it got to run bad. Was it after a boost run? After new plugs and wires? After??
milky 1704
026TB4U
Yeah it was after a quick race
It was running great and then all of a sudden just sputter. It would run fine until 10 psi then kinda stutters
IGottaSy
1. How long was it parked?
2. Do you have anyway to datalog?
There is this app called ALDLdroid. Have to see what fuel, O2, voltage is doing.
It would be a good idea to get a Turbo Tweak chip at least.
Need more info but I'm leaning towards a bad O2 sensor so far.
