stalling on hills? UPDATE Datamaster files available!
I was doing a datamaster run today after installing a new Shurflo intercooler pump and the truck died goign down a hill and climbing a hill. It has never done this before. Datamaster didn't pick up any codes at all. It is basically like I shut the engine off.
Any one have any ideas?
TYRODD
My ass. Look at it.
midnightbluS10 said:
It may be a stupid question, but how much gas was in the tank?
What he say.
These tanks have no baffles. My Ty as well as my Blazer have done the exact same thing. Starves the FP.
I had a full tank of gas in it. The same thing happened to me last night when I was going down a hill and it cut on me. I filled up the tank cause I only ahd 3 gallons left in the tank. It also died on me when I was driving down a flat highway today as well.
I realized today that it was not the gas tank because as it was about to die (die like the truck was turned off, not a bogging down kind of die) the tac would flutter drastically. Signs of the truck about to die would be a hiccup where it felt as if there was no combusiton in the engine. Could it be a bad coil?
ABLITZ
Damn Yankee
i had a similar experience when the ecu took a crap..was goin down hill[on a off ramp] and as soon as i hit my brakes it died,like i turned the key off..let it sit for 20 mins.,started up ,drove it half a mile then it died again..
let it sit,half mile later ,dead.
might wanna check the ecu.
were there any other signs of ecu failure that I can look for? How much did the ecu cost to replace?
I took the ecu off and reseated all the connections on it.
SeattleSy#1255
Category 5 Conservative
If you don't think its electrical, alt or other then try to start at the basics...
combustion=fuel or spark...i'm saying this because you described it as hiccup.
so fuel---fuel tank empy, poor gas (really bad like water in it etc), fuel pump, FPR think about that etc etc.
spark---plugs, wires fried, cap guncked up, rotor shaven down or even on wrong (I did that once), ecm, etc etc.
just start at the basics (tune up stuff) and go from there.
I have reason to believe that it isn't the fuel part of it, because the tachometer went crazy right before the truck died and also as it was "hiccuping".
