On 2002-01-25 16:59, jhacking wrote:
IAC? what is that not up to date on all the abbrevations
I found this in the archives... at
http://www.syty.org .....
The IAC is actually the Idle Air Control valve. It is a stepper motor that
controls the amount of air allowed to bypass the throttle plate. With the
valve, the computer can closely regulate the idle speed, even when the
engine is cold or when there is a high engine load at idle. It's located
under the throttle body facing the firewall (yep, a tough spot to get at).
You need a 1 1/4 " wrench, or 32 mm. Of course, you have to remove the
electrical connector first. According to ATR, the best stuff for cleaning
it is "Chemtool". Apparently, it is known to get nasty and affect the idle
quality.
You have a scantool? If yes, look at the IAC and see what number it says. Read the archives you might find that ~20 is desireable. You can adjust the screw in the throttle body to adjust this number, and it will raise/lower your idle. There might be a metal cap over the screw that you have to pull out. I did this and the problem was fixed. All your doing is opening the throttle plate a little by turning the screw while engine is running and your watching the IAC numbers on your scantool..
This is so that the IAC doesn't have to work as hard to keep you at desired idle. You could be so far off that you are out of the range for the IAC to work. If anyone wants to clarify this I could be off a little , but thats how I understand it.
Scott
