Re: Standard Bore Forged Pistons?
Federal Mogul bought Speed Pro but Speed Pro parts are still available under the Speed Pro name (Summit or Jegs) . TRW pistons were discontinued about 30 years ago before eutectic and hyper-eutectic pistons were introduced. .
Speed Pro L2256F forged pistons are VMS75 or 4032 aluminum alloy which is 11% eutectic silicon content and was introduced in the early 1970's. They use standard tension 5/64" top and second rings and 3/16" oil rings for long life. Unlike 4032 hyper-eutectic silicon, 4032 eutectic silicon is aluminum soluble on a molecular level. That makes 4032 eutectic silicon pistons stronger and less brittle than 4032 hyper-eutectic pistons that have the same silicon content.
Good high performance forged eutectic silicon alloy pistons have oil return slots rather than oil return holes in the oil ring lands. That is because the 4032 eutectic silicon alloy pistons are stronger, less brittle and can be fitted with as much as .0035" - .004" clearance. Cast or forged hyper-eutectic silicon alloy pistons must be fitted with .001" - .002" clearance which makes them pollution friendly, comnpared to eutectic pistons, which may not allow the vehicle to pass more stringent pollution inspections. If you are going to install a turbocharger or use the blue bottle, the flat top Speed Pro L2256F pistons are not for you and the 1/16" rings will be fine. That is because the engine will not last long enough to wear out 5/64" rings. .
The metric rings used on stock hyper-eutectic pistons are excellent for a stock engine in a vehicle that is driven daily. My stock 4.3L TBI engine lasted for 160,000 miles and had excellent compression. It only used oil because of the stock valve seals.
