started up my new engine, little advice?
bezerk
well...today i finnaly got finished building in my trans and engine..
here is what we have...
at idle oil-pressure is around 60 (spa gauge)
i can here some knock, i hear it more in the cabin than under the hood (feulline hitting something?)
using ngk 5 sparkplugs, the shaft is about 6mm longer than the oem CR42ts (using vortecs).
going to set my timing tomorrow. and my gauge for feulpressure is on it's way, so should u use the stock FPR? so base FP is at 42?
my build
#50 injectors
vortec heads
tr5 plugs
ultimate
4bolt mains
eagle rods
srp pistons
412 cam
stock turbo
1.6 ratio rockers (with stock valvecovers)
i would really like to drive this thing tomorrow, so all your help is really aprictated!!!
used semisynthetic oil 10W40
nick041881
i have a similar build as you. i started with mobile 1 synthetic and my motor made some wierd noises too. taking the advice of my builder switched to a thicker non synthetic oil and the wierd knocking noise went away. i dont have a surefire explaination for why, but it worked for me. i definatly would reccomend an adjustable fpr, really helps to get the tune just right. good luck! it is scary driving a new motor for the first time! btw are you planning on going bigger with the turbo???
AlaskaTy
I got my engine built by RPM and Mike recommended Penzoil 20W50 non synthetic. It's thick and it'll help really lube everything up while also getting the new build metal out. Plus it's cheap so you can do your first 4 oil changes for about $50.
bezerk
20w50, no where in the netherlands....
i will just use some 10w40, cause it's cheap and a little bit thicker than the 10w30, and it's cheap to!
RPM builded rotating assambly too!!
DanenGraham
Big in the rear
Dont use Syn oil for break ins. I have heard this from many of people, just dont do it. I wouldnt put it in for at least 1000miles, Hell you will have changed the oil two or three times by then anyways so save some money.
MikeRenz
not stock
i used mobil 1 right away on my very similar build. My motor made no knocking noises......until one of the rockers came loose and started smacking the valve cover. The rockers are something that you should check anyway after a few miles.
Vaders Sy
I have a similar build too! The engine builder told me not to use synthetic because it is to slippery and will not lubricate the motor properly. Also, he mentioned that the seals would not seal if I used synthetic. I was told to change the oil every 100-120 miles until 500. I have changed the oil 4 times and will probably change the oil 2 or 3 more times before 1000 miles.
Bezerk,
Get a fuel pressure gauge from an auto parts store. Hook it up to the schreider valve (spelling?), adjust, and reconnect the line and your ready to go. I think the boost gauge contraption is about 20 bucks at the auto store.
nightdiver
Rene,
i did my first oil change after 150 miles and will do the next one at 500 miles.
YOUR ENGINE BEGS FOR A 60-1 :D
