starter alignment?
TwistedTy
More boost! N.A.S.T.E
just got finished putting the coolant plug into the block. Now i removed the starter but am not sure on how to align the starter to the flywheel. everytime i think it is aligned, when i tighten the screws the bottom of the starter moves back and then creates an off gap between the transmission case and starter but a good seal to the tranny case and starter at the top. the gap is only at the bottom. Any ideas?
PPI Typhoon
DIY Madman
Re: starter alignment?
Mine didn't have any shims nor did it require any aligning. I remember a slight gap there too, but it still started just fine. :?
TwistedTy
thanks i got it hooked up just waiting to finish bolting the rest in. thanks for the info
