starter motor for bowtie block
waypen11
What starter motor will bolt up to a bowte block? The diagonal mount for the sy-ty won't work. The bowtie requires a straight line bolt pattern-parallel to flexplate.
myclone
Re: starter motor for bowtie block
Both the cheapy and Tilton mini starters I have are in-line if you want to go after market. If you want to stick with GM stuff then lets see.....good God its been eons since I ran into this....I think a stock 400 SBC starter is in-line and maybe the BBC stuff is too. There are other SBC starters that are in-line but I dunno what applications they are right off the top of my head.
myclone
You got my curiosity peaked so I did a little digging in my old Bow Tie parts catalog. Looks like you can swap the starter "nose" where the bolts go through that hold it on the block.
In line bolt pattern nose GM part # 1968122 . Thats a really old part # so its prolly not any good but if you have a parts man worth a flip he/she should be able to cross reference it for ya.
waypen11
Thanks! I was thinking that maybe th Tilton might work. I had one on a grand national motor with a straight bolt pattern.
ed hess
race or get outta the way
dont think i saw any difference when i took the mini cvr starter and put it on my bowtie block. used the same 2 shims to get the same clearance. the same clocking on thes starter... just bolted ot onto the new block.
ed
