Nitrous
Hey guys, sorry for not posting in a while but have a lot going on. I have an electrical question that I wondered if someone else had the same problem. First off I pulled into the gas station and filled up with gas. When I went to start the truck I could smell electrical burning and the starter wouldn't even do anything, no solenoid movement. I towed it home and replace end the switch on the steering column, solenoid wire and new hi induction starter. I drove it for a couple of days running great. Tonight I pull up at the store and after 20 minutes of shopping I go to start it and nothing. I check everything out again and start it again but this time it starts and won't shut off. I turned the ignition switch a couple of times trying to get it to stop with no luck. I jump out and disconnect the battery but the starter was smoking at this time. No big deal because it's under warranty. I think the contacts stuck in the switch but always value you guys opinions. Sorry for the long post but I wanted to make sure I had everything in it. Any suggestions? I'm a mechanic and mainly build Lsx engines but this is the first time in my 35 plus years of working on trucks that this has happened.
