starter wont turn over engine today?
ilandaze2
went to start my car today and the starter wont turn the engine over. the starter was trying to start because i could see the voltage drop but she didnt turn over. i opened up the hood and let her cool off for like 10 minutes and it turned over. i know that the starter always had trouble turn the engine over but this is the first time today she didnt turn. i did upgrade the alternator wire, starter wire, and battery ground but i didnt do the engine ground. the starter is brand new. i changed last december. any ideas? i was just driving around the neighborhood for half an hour so she could of got hot. i was looking for an apartment and just cruising around and its about 90 outside. my brother said there was a lookout solenoid you could buy? i started like 4 times at the house and it starts fine......?
cloneman315
Re: starter wont turn over engine today?
it still could be the starter,everyone thinks that it is always the purple wire ,but its not the heat damages the solenoid and the starter,when u get a new one wrap it with heat wrap and u will have no problems
Black Knight
I Glow Therefore I am
Try testing your battery and double checking all connections are clean and tight.
Lookout solenoid? :dunno:
If he's thinking about wiring in a Ford solenoid, there's no need if everything is in good working order.
Put a voltmeter across the bat terms and hit, er, engage, the starter and watch the voltage. I've not done this to a Sy but guessing anything much less than 10 indicates a high current draw to the starter, IE bad starter.:2cents: it would be unusual but if you have a high amperage clamp-on amp meter you can try that on either bat cable.
jjorgensen52
NHSTE - I'm the only one!
I just had this problem the other day with my GT... my truck was warm and would not turn over with the key, heard it click once and voltage dropped. My starter is about a year old, so I tried the old screwdriver across the contacts trick and it fired right up. My problem was that the ignition wasn't putting enough current down through the purple wire anymore, not the purple wire itself. Just a thought, something to try
If you can get a screwdriver on those terms on a Sy :roll: go for it. Excellent test. I know they're there, just need another joint in my arm.
ilandaze2
just drove the car up from the house to the grocery store and not problems. about 10 starts and no problem.
You should still check the timing if you haven't done it already. Very important. Let us know if you need instructions.
ilandaze2
how do you check timing on these truck anyways. do i need a timing light and is the crack pulley marked? i plan on buying the datamaster soon.
jjorgensen52
if you haven't got the fenderwells in it's easy :lol: ... I know I've done it by accident on the Ty before... scared myself silly doing it
Black Knight
Yes on the timing light, it's recommended to do a TDC check first because our harmonic balancers like to walk around themselves :tdown:
Loeryder
IF you aren't getting full voltage at the solenoid then its time for a hot shot relay.
I didn't believe in them at first either, but after studying the starting circuit and how many switches / voltage drops the Pos wire goes through to get to the solenoid it makes perfect sense.
Since installing the Hot Shot relay I have had ZERO click no starts.
I like the CVR MiniStarters because the mounting block can be clocked at any angle to rotate the solenoid away from the downpipe.
Just my 2 cents, and I don't need any change, thanks.
ilandaze2
where can you get a hot shot relay. this starter always seems like its had trouble starting. it was better after i changed the cables but it still has a hard time. why is it so hard to turn over these engines? is the compression lower on turbo cars. what brand timing lights do you recommend?
Syclone'D916
Syclone Owner #2414
My SY had the same problem, it would just click when i turned it over,I got a high torq starter and moved the wires away from any heat,now it starts like a Champ.
pinellas50
New Guy
I would suggest, during the no start situation, having someone turn the key while you lightly tap on the starter itself with a hammer. Often times, when a starter begins to fail the brushes inside stick to the case and tapping it will free those brushes and let the starter turn over.
jjorgensen52
I used an accessory lighting relay, 30 amps, weatherproof. Came from the local Pep boys type place
