Neelsonwheels
Well I got the truck all back together with boat loads of new parts. I fired it up and it idled and ran beautifully. I am getting it ready to be tuned due to new throttle body and larger turbo. I jacked the truck up and change the Trans cross member out to the sweet one I bought from JSM. Thanks by the way Jeff!! So I lower the truck and want to take it for a little spin. Turn the key and it just doesn't want to start! WTF. Try again and give it a little gas and it starts but not well. Smoke and stuff (due to fuel I guess) won't hold an idle. I have to feather the gas. After a minute I can remove my foot and it idles perfectly. I changed the intake air temp sensor back to a known good one and no change. All the vac lines are new,plugs,cap,rotor,wires are new. MAP sensor new,throttle body new,engine temp sensor new,coolant sensor new. My fuel pressure gaug reads 43psi at key on. I am leaning towards the IAC motor. Any other ideas? I am getting pretty frustrated. thanks
