Starting the engine for the 1st time
Syclone#2960
What ever it takes!!
Anyone give me any advice on what to do and not do.
How long should I let it run before changing the oil and at what RPM.?
Should I run Synthetic oil at first or reg oil?
I have never done this before and could sure use some advice from anyone.
TIA :oops:
________
Toyota sequoia specifications
Falco
You should prime your engine first with a prime tool. You should not use synthetic for the breaking, no point to waste money. If I were you, I'd run the engine for ~20 minutes for the first time and would try to keep it around 2000 rpm. Monitor your oil pressure closely (not with the stock gauge). I'd change oil after that and after a complete cool down would restart it and put a few miles on it. After a couple of heat cycles and, let's say, 150 miles I'd change the oil. The third oil change would come at ~500 miles and that time I'd put in synthetic and would start pushing it incrementaly...
HTH,
tealty
I remember reading somewhere that for engine break ins, its best to beat on it from the get go. There was a site about it....i'll see if i can find it. But yeah definately prime the oil pump and use regular dino oil.
later
Jordan
DanenGraham
Big in the rear
Run for atleast 15min at 2K RPM. Your timing isnt a really big deal right now, just get the thing running and keep it running- you dont want to start it more than a few times right now.
Change oil (dont use Synthetic on first two changes)
Put 50-100 miles on it, you dont have to baby it. Go through the rev range alot, you dont want to put any boost to it though so dont go hammering this thing.
Change oil once again not Synthetic
Drive 100-200miles
Change oil (and use the good stuff, snakes and sparklers)
This is what i did, I put a good 500miles on my new motor before it saw anything past 2#'s of boost.
Syclone#2960
that sounds great guys,thanks.
Right now I am chasing water leaks and stuff of that nature.Engine builders did plug the 2 water holes under the block.Those Fawkers.
________
DIGITAL VAPORIZERS
Syclone#2960
Well it fired right up after the 3rd crank and it sounds fantastic.After about 10 mins of 2K rpm the steering pump said good buy.I should of checked p fluid in it :oops: I removed the pulley and when I wigggle the shaft it leaks fluid.
________
Hotwildsexy69
ItsMyTy
Life is beter at 25 PSI
i thought the running at 2k rpm right after starting didn't apply to roller cam engines?
SY#2910
Banned
Roller cam engine do not need the break in like a non-roller cam engine does to seat the lifters seeing that the lifters roll on the cam lobes.
Syclone#2960
typhoon92 said:
Hey, Bruce
Don't forget to send me some pictures of your syclones engine compartment.
thanks,
Will do Sam as soon as I work out the bugs. :p
I had to replace the power steering pump andnow it leaking at the hard line that plugs into the steering shaft.
________
Hawaii Marijuana Dispensaries
VermontTy
Support Our Troops
My brother used to work for Caterpillar, and said they stressed the same thing as the 'busa thread. Once it kicks off, make sure oil pressure is there, all is safe, and throw a brick on the gas. If it's going to let go, it will in the first couple mins. If it makes it through that, it'll make it through anything.
Not sure about that theory... :-?
93ty475
i would be careful dogging on it the motor just in case something in the valvetrain lets go...sure, if its not going to come unglued, it won't, but you don't want to grenade the motor if something lets go...there are alot of moving parts under the valve covers and if a problem arises, you need to be able to shut down immediately to minimize the chance of damaging something 'down under' that'll require pulling the motor again to fix...after running it a few times in your driveway, it might be a good idea to recheck your valvetrain now, especially if your fenders are still off...make sure the rollers of your rockers are rolling on the center of the valve tip... edit: are you running cometics? if not, do you plan on retorquing?
Syclone#2960
Well 500 miles now and I am picking up false knock at 2100rpm.
There is a small oil leak somewhere.I am finding little dots of oil on the floor when I drive out.
What is the best way to get to the knock sensor, I over tightened it. :oops:
________
Glass Pipe Pictures
Falco
From off hand, I used to remove the bracket which holding the coil and the map sensor (hopefully you don't have egr any more :D ). Now you can reach down to the knock sensor if you are trying it hard enough. Push both side of the connector and pull it off. You can use a big socket (I can't remember the size, around 22mm) to loosen the sensor itself...
HTH,
Syclone#2960
Thanks Falco, I will give that a try.
I luv this new motor and turbo combo I got now. :p
I cannot wait to install the aluminum drums and the alky kit and the smaller race pulley and the electric fans.Danm will this ever end? :dunno:
Oh and wrap the down pipe and intercooler.My intake temps have shoot up quite a bit more on a full throttle run 180*. :(
________
Easyvapedigital
Syclone#2960
HTH,
Your are right on the size(22mm).I think this was the hardest thing I ever had to do on the syclone.I would have rather replaced the motor mounts.It was hard to unclip that wire.
I think I found the source of the false knock.The fuel lines! are not bolted down to the bell housing.
WHat do you think is the most boost I could run on 93octaine without the use of Alky?
________
Mercedes-benz cl-class history
