Jamerjoe
I want to replace the two fuel lines that runs from the transfer case connection with the 2 rubber ends to the fuel rail and fuel pressure regulator. Does anyone know what sizes to use to keep stock dia. size and what fittings to use? When I looked at it, it seem the fuel line running into the rail had the same size fitting on both ends, which took a 5/8 to undo, and is a larger dia. then the one going into the fuel pressure regulator. Also the fittings going into the fuel pressure regulator are smaller size on both ends. Can anyone please help me out?
