Steering Pump pully ??? Need Help
DanenGraham
Big in the rear
OK, i put this in the tech then the mod and now in the lounge.
On the Power S. pump, the pully (stock) has flared up sides to it, On the one i just got from Autozone, it is just a normal pully, but the guy asked if i wanted straight when i bought it, (i didnt know there were two) So is it ok to use the one i bought with the straingt sides, or do i need to get the one with flared sides.
Thank you
DG
leroy
It's kind of hard to tell what you are talking about Danen. It should be the same diameter as the one that came off. Make sure it is for a serpentine belt and not a v-belt. Make sure it presses on to align with the other accessories. Other than that, I don't see how it matters if it's straight or flared. If it doesn't work, take it back and get the other one.
HTH,
Jim
DanenGraham
Big in the rear
Thanks, i have never seen a pully like the one i took off, my new one is the same just normal, the one i took off, looks like the edge is bent but, like it came that way not bent.
