Bad Ass Black Trucks
Finally got my Typhoon back together and I am having the heck of a time getting it running right. I put in a used motor with 114k on it as a hold over till I get the funds to properly finish a built motor. The truck almost complete, save for the intercooler pump and some plumbing.
I think I have multiple mechanical/electrical issues that are making things difficult. I had 63# siemens injectors in it and downloaded several different bins to use with my ostrich. The truck started fine with but was running very rich. It was idling smooth but at about 9:1 on the WBO2. I adjusted the F28 table to try to bring the AFR up at idle but it started to run rough and the AFR started to swing between 11:1 and 14:1. The RPM was also oscillating up and down which I think was due to a misfire. Different bins seemed to behave more or less the same.
I also noticed in my logs that when cranking the RPM shot up to 6300 RPM. I did a lot of searching on here and discovered that it is due to an ignition problem. After that I decided to put a set of stock injectors in and go with the memcal that was in the truck when I bought it. I figured that would eliminate a variable and make things easier to sort out.
No dice. Couldn't even keep it running. I checked the timing, verified the timing mark was correct and went over the firing order multiple times and it was correct. FP was ~43 PSI with engine running and vacuum hose removed and plugged. I swapped out the ignition module from the e-bay distributor for a stocker that I had sitting around and put in a used accel coil as well.
I was going to check the timing again and got the dizzy a little off and now the darn thing won't even start. It is dumping tons of fuel and is having trouble cranking. Plugs were soaked with fuel. Fuel pressure does not drop so it isn't a stuck injector. Had ~20 PSI after two days. Battery had a good charge as well.
What should I target next? Get new ign module and/or coil? Do I have a bad ECM? Bad wiring? I checked the grounds and get 0.1 Ohms from the core support to the intake manifold and 0.0 ohms to the firewall.
Why did it run so well with the 63# injectors at 9.0:1? Why can't I get it to even start with the stock injectors?
Specs
Block: Stop
Cam: Stock
Injectors: 63#, then 33#
Intake: Lightly Ported upper and lower
Turbo: 60-1
Wastgate: External
TB: Stock
Map: 3 Bar
Exhaust: Stock Manifolds, 3" Downpipe, No Cat, 3" SS
Fuel Pump: Hot Wired 255 LPH installed by the previous owner
Distributor: New E-bay special
Wires: New Taylor
Plugs: UR5
Intercooler: ATR Upper and bigger pump
Wideband: NGK AFX wired into the ECM
Specs
Block: Stop
Cam: Stock
Turbo: 60-1
Wastgate: External
TB: Stock
Map: 3 Bar
Wires: New Taylor
Plugs: UR5
