Stock alternator voltage output?
IGottaSy
Just for reference, what is you DM showing as max voltage of your stock alternator?
Mine went out soon after I got the truck. I had one from a '94 S10 with same engine and auto 4l60e. Needles to say, it was not a bolt-on part. They are clocked differently. What I tried was a combo of the two alternators. I used the front half from the Syclone and the rear half from the '94 armature and all. Bolted the thing back together using the tailgate for a work bench because I don't have a work bench and plus it's dented up a bit and full of scratches so it doesn't matter. With the alternator back in the truck and DM connected, I was pleasantly surprised as it spit out a maximum of 14.1 volts. It has been running for months without issues. I've read for the most part how the majority of the alternators put out 13.5-13.8 volts on regular basis on all my older cars. Headlights are nice and bright:tup:
