Stock Block rebuild
coupecustom
I pulled the motor out of the Ty about a month ago. Thought I had a head leak, more than likely it was the china wall. Wanted to pull it anyway cause of the motor mounts, a front diff leak and oil cooler line leak.
Now that the engine is completely disassembled and cleaned, I need to put it back together. I got the crank polished, its in spec. So for that I just need to buy some bearings. Moving on to the pistons I'm not sure about the rings, do I replace or not?
I measured the piston bores, they are all in spec at 4'', and in great shape, no heavy scratching and therefore I see no need to go bigger. The top rings seem to gap at 30. I couldn't find what factory should be, but regardless, I'm wondering if you all recommend new rings or not....and if so which ones?
My build is...well...medium. The bottom end is all stock...stock block, stock pistons, stock rods, stock oil pump, ect. Top end has a little more excitement: 412 Cam, Vortec heads, stock rockers, stock valve springs, stock push rods, 60lb injectors.
After her bath:
Re: Stock Block rebuild
Difficult question actually. Depends on your budget I guess.
Take it to a machine shop and have it hot-tanked. Line-bore checked. Light cyl hone to bring the cross-hatch back, and deck it so you know it's true and flat. Same with the heads. Disassemble, hot tank, guide check, Light mill so they're flat, 3 angle valve job, reassemble with new seals.
Never install old rings. Ring end gap itself is not terribly critical just be sure you have the minimum. New rings are your choice. I like King main bearings only because they have a 3/4 grove = more oil to the rods.
New timing chain and sprockets. Unless you kept the lifters separated consider a new set of stockers, not that much $$.
If the front oil passages only have the little freeze plugs in them drill and tap for flush pipe plugs.
Do a search on head gaskets.
All new exterior "freeze plugs."
Might consider having it balanced but that requires the rods and pistons be separated.
When installing the rear main seal make sure it is truly centered on the crank or it will leak.
If you skip all the above at least change the freeze plugs, ball hone the cyls, install new rings and valve seals.
Just my :2cents:
Should make a nice motor.
berzerker
wookie
do not re-use the stock valve springs !! have them matched to the 412 cam or at least use the alex parts units . look them up at alexparts.com it will save you a headache . they allow to use the stock stye while have the clearance to the cam lift .
coupecustom
These are the main bearings I found as you suggested Don:
http://www.summitracing.com/parts/kgb-mb445si/overview/
For rod bearings a matching set of King's should be fine right?:
http://www.summitracing.com/parts/kgb-cr6625si/overview/
I like the HP series, but its a little over the top for my current build. Eventually I'll pull the motor again and do a good bottom end build. But for now this quick budget build should be great with mostly factory stuff.
For rings, would these work? I'm wondering if the turbo charged applications require a better grade ring set or if there's any difference at all in what came from the factory?:
http://www.summitracing.com/parts/slp-e-229x/overview/
I've been to alexparts.com, and saw their springs...just didn't think the lift on the 412 was enough that the factory springs could not handle it. When I get to that part of the build I'll take a closer look.
The factory springs will be binding at 0.500 lift. I don't remember the exact number but somewhere around 0.450 is the limit.
coupecustom
Fair enough. I'll grab springs when the time comes.
All the freeze plugs were removed for the engine cleaning. Then I cleaned all the oil passages with a brush kit I have. Love the idea of tapping for flush pipe plugs, but probably not going to bother this time. Its not going to the machine shop this round. Its just a little refresh.
With the bearings and rings picked out now all I need is to grab a ball hone, order, and assemble. O...plus clean the pistons in some gunk.
coupecustom
Can someone recommend a double roller timing chain?
Would like to order that at the same time.
A "good" timing chain kit will come with a 3 keyway crank sprocket. You might consider degreeing the cam. Small degree wheels can be had cheap. If you have a dial indicator probably something to check if you have the time. I ran a 412 in the past, didn't degree it. Current "custom" Comp cam is.
kmack
Replace 9# bypass valve at oil filter adapter with 21#unit:tup:
This was GM service bulletin.
Loeryder
I have a lightly used 412 cam, gm cam retainer plate and matching double roller timing set for sale if you are interested.
Also have a set of brand new ARP head bolts and Comp 1.6 roller tip rockers I am not going to use.
coupecustom
Progress has been made. I ordered up all the bearings and a ring set as linked above. Then yesterday my buddy Mike came over (turbo Ford guy, but loves the Ty too) and we successfully used the ball hone to get some good hash marks on the cylinder. Its a messy job, but I'm very happy to see the results. Once done, we washed the engine again and again and again, making sure it was completely clean.
Next up was to clean all the caps, bolts, ect. I used a gallon bucket of Gunk. Acetoned the bearings and then plasti-gauged all the mains to verify they were in spec. They were. Last step was to install the crank for good. We used a moly assembly lube and dropped the crank in place. Tightened the mains to 80ft#'s in three stages and finally checked outer bearing clearance, it was in spec too.
Now I've started to work on getting all the pistons clean. Dropping them in the Gunk for several hours then brushing with a nylon brush, cleaning the ring grooves and dipping them in a solution of water and dish detergent. Finally using my air compressor to air dry and then wiping them down with a paper towel.
3 down, 3 to go
Couple reminders. The rear seal doesn't "automatically" center itself on the crank. (Mentioned in previous post.) Pre-oil before starting. Couple options:
http://www.summitracing.com/parts/sum-901010/overview/
If you have or plan on getting one of these make sure it has the lower section that directs oil past where the dist goes. Otherwise you're just pumping oil back to the pan, not to the bearings.
Or you can do what I've done many times. Leave the plugs OUT and just spin the motor with the starter until you have oil pressure. This could even be the better way because it gets oil to all the rod bearings. Remember the rods aren't oiled all the time depending on where the hole in the main journal is.
Or do both which is the way I did it the last couple of times.
HTH
I used my drill to turn the oil pump.
That's a good thing as far as it goes. Which on a stock SyTy is a long way due to the external oil filter but if you don't seal the distributor passage you're not priming the engine itself.
Dry starts, especially without at least priming the filter system, are rather detrimental to bearings.
coupecustom
Thank you everyone for the tips and tricks. I'm taking it all in, so your words are not lost.
I just spent the last half hour methodically inspecting the four clean pistons I've done. So far so good. I can't identify any bends in the rods or cracks in the pistons(thanks Dave ;))...which I'm actually a little surprised about, knowing the history of the truck. There are a lot of little pin indentations on each piston surface. I believe that's a cause of knock, but not positive. Its not bad enough to warrant new pistons though.
For the rear seal I have a one piece. I believe that will help a bit in centering, but won't know till I get there. Thank you Don for the link to the oil pump primer. I've not used one, but sounds totally worth it.
Something I had not shared yet is that I did get cam bearings as well. I hadn't planned to replace them, but they were the most worn bearings in the engine surprisingly. Again I didn't want to go to a machine shop with the engine, so I pulled the old ones myself and will reinstall the new ones shortly.
Heres the tool I got:
http://www.amazon.com/Allstar-ALL96470-Engine-Bearing-Installation/dp/B006K8WCYS
Money spent so far on this endeavor:
Bearings, timing set, new dip stick tube: 218
Ball Hone and Cam bearing tool: 78
Polished Crank: 30 (I could have done this myself too, but for 30 bucks, why)
Plasti-gauge, Gallon of Gunk, and some brake clean: 28
I'm with Dave on this one. I let someone else do them. There is no reason that I'm aware of keeping you from removing the crank to do the cam bearings and making sure those passages are clean. Once installed you should be able to literally see from the main bearing "saddle" through the cam bearing. A little back light will help. Short of this how do you truly know they're in correctly?
Dave PMed me on the rear main seal. There should be a couple of dowels aligning the rear main seal. See if they are both there. All I know is I had to pull an engine a few years ago because I didn't properly center the seal over the crank. The leak was amazing!!!
These are not cheap but if you're considering additional rebuilds they make piston installations a piece of cake. The problem is they have to be your exact cyl size. Ring breakage on install drops to virtually 0.
http://www.jegs.com/p/ARP/ARP-Ring-Compressors/747505/10002/-1
coupecustom
Big update. I'm nearing completion of the bottom end.
I ended up having to pull the crank as Don mentioned. Simply put there was no way for me to even install the bearing on the tool let alone align the oil holes with the crank in place. So I pulled the crank, made sure to clean the cam bearing holes and then hammered the new ones in. Sounds violent, its not. Two of the bearings I didn't get the oil hole aligned very well...so, I punched them all the way through and tried again. To make sure the oil hole was aligned with the block oil hole I used a piece of wire that would fit through the bearing hole and then made sure it was going down the oil hole. To do this you set the engine at a 45 degree angle so the oil hole in the block is going straight down. Worked like a champ and thrilled with the results.
Cam bearings going in. You can also see how nice a job the ball hone did.
Next, of course I reinstalled the crank. I had a bit of trouble with the main oil bearing, making sure I had sufficient end play clearance, but once I got it set properly the crank spun with ease.
On to the pistons. This took what seemed like all week, because I had to leave the piston in the gunk long enough to break up the carbon on the top of the pistons. I also cleaned the rod caps, bolts, ect. To do the rings, Don sent me a very nice PM outlining the position for each ring. It lined up with what I had in another book as well. So I set the rings up and used my piston ring compressor to get them in the block. For the rod bearings, I used some acetone to clean between the bearing and rod on both the rod and rod cap, then installed the new bearing and last used an assembly lube on the bearing. To install, lined up the piston with its hole, dot facing forward, and used the wooden end of my hammer to push them down.
For every rod I used the plasti-gauge to verify the tolerance between the rod journal and bearing.
All done with pistons and rods
Last part, I did today, was to install the 412 cam I purchased from another member, lightly used. It was kinda my christmas present and will go good enough with the vortec heads I plan to get. Cam install was easy, add assembly lube to each journal and slide on in there. I also installed the cam stop with a little anti-seize on the bolts.
Next up is to remove the crank gear and install the new one for the double roller chain.
Damian
One thing I'd do is use tons of lube on those bearings when you install them. I used Lucas Oil Stabilizer and lots of it when I did mine
coupecustom
Been over a month since I posted an update. Unfortunately, not as much work as I would have liked to have gotten done over the holiday's...but you all know how that goes. During the time I did manage to get the following done.
Pulled the crank gear. Major PITA. The tool I was using had pushed against the threads on the crank bolt hole enough to have actually stripped a few of the threads on the inside. This was my fault and inexperience. I should have known to make sure the long bolt on the tool was pushing against the main surface much better. O well live and learn. I made up my own end to make things work. A pic below. Then when I was done, chased the threads to make sure it will still work. Once the gear was off, I heated the new one up, as advised, and it went on with a quick and very light smack from a hammer. Very easy install actually.
Next task was to install the oil plugs I had removed earlier in the cleaning process, that sit behind the cam sprocket. I then figured out the rest of the install for the timing chain. Installed the cam sprocket, torqued the bolts to spec and voila, looks great and functions very well in my opinion.
There is so much less slack in the double roller chain, I think it will help.
I went ahead and installed most of the freeze plugs and also put back in the lifters and dog bones. Last was the splash shield / lifter retainer. Which brings me to my question for the evening. The 412 cam I installed....has anyone used the factory lifters, dog bones and retainer? Seems like the cam may have just enough lift to bottom out the lifter travel against the dog bone since the retainer / splash shield is torqued in place. Maybe I'm over thinking it....but still seems real close to me.
