Stock boost levels?
Syclone2163
I just installed a boost gauge on my truck and was wondering what boost i should be getting at WOT. Right now it seems im at a max of 10 lbs.
jwaller
Evil Genius/SyTy Guru
well you should see 15....or very close to it...so you need to fix something....sounds as if you are not getting any bleed off from the WG solinoid...BC thats very close to base boost....what are your mods?....what chip do you have? what turbo?
I asumming you have the boost guage in the properline (not the Throttle Body line) I would check/replace the wastegate vacuum lines and electrical solenoid connections. My truck get approx 9 lbs of boost without the wastegate soleniod connected.
Tooky
Serious about performance
I am thinking the exact same thing as dgoodhue. When I got my truck I got the 10# max boost problem too. Took me forever to figure out until someone at a SyTy gathering pointed out my wastegate solenoid connector was unplugged and neatly tucked away somewhere in the bowels of my motor. Boy did that make a difference in spoolup and performance!!
