Stock Chip ID
Vertigo
Addicted to Turbo AWD
I've been searching for a half hour so forgive me if it's been covered.
What are the markings on a stock 92 Typhoon chip? I'm aware GM did some swapping with the early Syclones (?) but not sure of the Tys. I have what appears to be a stock chip with a strip of foil over the eye and the handwriting "MAZB -5" on it.
Has my chip been reflashed do you think? It's a 128k and the socket does indeed look like it was tampered with...definitely not a robotic install, that's for sure. Did PAS mess with these?
We've recently purchased the truck and it came back from Japan with this chip. The timing was retarded by 2-3* but I think it was because of detonation from a stock plug/wire/cap/rotor problem at 51k miles ;)
thanks in advance
turbodig
Re: Stock Chip ID
thanks in advance
There are some PAS hand-burns floating about. The writing above doesn't follow their typical nomenclature, though.
Doubt that it is a PAS burn... probably someone's DIY burn.
Later,
Vertigo
Re: Stock Chip ID
What would be a typical marking on the chip? It's definitely either a PAS chip or a reburn, like you mentioned, as opposed to an aftermarket or piggyback chip.
Vertigo
Re: Stock Chip ID
Thanks guys.
I'll take some detailed photos if I can. It's definitely none of the PAS chips or even the general aftermarket from what I can tell. I would suspect the -5 would be for less timing however with all new ignition it still knocks (audibly).
The chip must be designed for Japanese fuel too. I'll have to do more research.
turbodig
Re: Stock Chip ID
Vertigo said:
Thanks guys.
Audible knock = shortly dying motor.
Find yourself a stock chip to plug in while you're figuring it out.
Later,
