stock chip & te44
kwick6
Re: stock chip & te44
Maverick87 said:
will it work ? I am trying to get rid of kr and would like to know.
don't know how well it'll control boost, but it will work.
Ian Turgeon
Cascading Inspiration
Shouldnt that be near the ceiling of the stock injectors anyway... which would pretty much fill you in for a set of 50#'s and an ultimate.
whats DM/Diacom/TL say?
kwick6
The stock injectors are running static as soon as you raise the fuel press above what they are rated for.
Some will say that is being in denial, and running an injector static will cause problems. I've had the te44 on my truck with stock injectors for about a year and a half, no problems. I've had it at 17psi with this turbo, no knock, and watching an EGT,02's, its not leaning out.
I don't know what my actual AFR is yet, but I'm sure I still have some room with the stock injectors. I won't know for sure until I have the WB02 setup.
FWIW, I think Todd A. ran stock injectors on his TE45 setup.
boost control isnt a problem I have the great atr wg :roll:
dm says that o2 volts are 970 and kr is 4* or less on 93 octane. The only problem is it has a 3* kr tip in. Which I dont understand. Knock counts dont show any increase but still get 3* kr. :-? I am going to the track the 19th we will see if it is any slower than the shit bull that I had in there. It does idle better.
