Stock Chip Tuning SoCal
Fitos
Anyone here can do some stock chip tuning on a stock truck only mods are egr remove and walbroh fuel pump with 160 thermo around the so cal area just want to get the most of a stock truck
Gnocide
turbo game burt reynolds
Re: Stock Chip Tuning SoCal
not a whole lot of adjustment for stock chips except the correlation between boost and fuel pressure.
if you dont have and adjustable f/p reg or boost rod/waste gate- never mind
fuel pressure- turn that up if adjustable + then back off when desired level of knock(none ) and 02 vales (900) are in sync with whatever boost can go to.
turn up boost to desired slowly until knock or a leaner condition is observed also if adjustable
you will need a way to monitor it like a scan master
hookup a scan tool and monitor for low 02 values and knock under wot.
It's just a six
Super Member
Just wondering why you removed the EGR valve?
You do not need to smog it?
Fitos
Well got smoged except this 2 years. Did it for Lower intake temperature that's why
It's just a six
Super Member
You do not need to remove it to keep your intake temps down.
Just unplug it if you want to keep your temps down.:2cents:
