Stock chip with 412 cam, will it work?
syclownz
In the process of deleting my ultimate set-up which is using the 50# injectors and 412 cam. My question is will I be okay running the stock chip, stock map sensor and stock injectors with the 412 cam?
Someone told me I might have a problem and with me not knowing a whole lot made me wonder.
Thank you
BoostedSUV
Re: Stock chip with 412 cam, will it work?
My truck did not run well with a stock chip/2 bar and 412 cam. Why are you ditching the ultimate and 3 bar? If I were you I'd have a cusom tune done and keep the 3 bar.
Slyclone
Well-known member
I run a 412 and my chip was re-flashed. Was also reccomended a 3 bar.
Truck apperantly will not run correct with a stock chip/stock map.
Again I dont know that much also.
syclownz
I was told by Hood that he couldn't reflash my chip and I'm having some major issues just trying to keep the truck running. All was well when I switched computers with a friend. all my issues were gone and then slowly they all came back even worse. Don't know what else to try.
BoostedSUV
Sounds to me like you have an issue beyond the chip. Anyways, going back to the stock chip/injectors/2 bar won't hurt anything but the truck will not run great. And KEEP IT OUT OF BOOST while you're testing to see if that's the problem. The motor will be running lean with that cam and chip/injectors so drive it but don't get it into boost.
syclownz
My goal is to figure out if the stock chip and or Ultimate chip is at fault by replacing/deleting them. I do plan on staying out of boost. I just want it running.
I checked some sensors and the tps had a glitch at around 3volts every time I checked it. smooth until that point.
The truck I worked on with a 412 and stock head cam ultimate did not run well. Ideally any head/cam change should have a custom tune.
syclownz
I am also using the Vortec heads with my cam. No one I know can reflash my Ultimate chip so I need to ditch and try a new chip/tune but I think I need to try to see if it is the stock chip first.
I already tried a reman computer from gmpartsdirect and that was a bust. Truck was running with friends computer but when I tried the reman it was going crazy. They wouldn't take it back nor did GM want to help me out so I'm stuck with it.
wildphil
I Love My Ty's
isn't the FAST meet this weekend in Miami? I bet you could find some help there.
0966Sy
Code what?
I would look into it being the map sensor that is bad, I had a truck eat my lunch with a bad map. Reason it did was that i changed it to a 3-bar map so it was a new bergwarner map so that was the last thing i thought it would have been. Thought it was a chip/computer issue also, The truck ran good for two weeks on the map before it went bad, once i found out it was a bad map i replaced it with a GM map. I wont ever run anymap besides GM from now on.
Syclone#2960
What ever it takes!!
It's worth a shot at this level.
