Stock exhaust... educate me.
Throws
OK... So I'm doing the PITA cat replacement, and as I lay under there, I have tons of time to ponder things. Like why my exhaust tip looks like it's shedding it's skin, like why the PO had a crappy exhaust job done (welds look like they were done by a middle schooler).
The biggest question though is: What options do I have for a "stock replacement"? Walker? Dynomax? Thrustmaster? What is sooooo special about our exhaust that most catalogs say "Exc Typhoon/Syclone"? I don't think the mid pipe is special, or the muffler (stock was a fancy Dynomax!), or even the tailpipe. I imagine this was all fairly off the shelf type stuff...
So, why *can't* I get a 2DR 4WD Jimmy tailpipe and call it a day?
-P
(Yes, I know the stuff RPM is shit-hot... I'm not making the power that necessitates a 3" exhaust. I'm 2.5" from the turbo to the tailpipe. I'll get a new DP when I crack the 11's)
5678TA
Re: Stock exhaust... educate me.
IIRC, most blazer/jimmy kits come with 2.25" tailpipes. that's why it's excluding syty's. i'd think performance companies wont sell undersized exhaust kits. and the blazer/jimmy is not a popular performance vehicle. the 4.3L will breathe very well with a 2.25" pipe if its not modified past bolt-ons.
Ty's had a 3" exhaust pipe already.
It's should be a Dynomax muffler with 2 1/2" outlet that necks up to 3"
Apparently stock is enough to necessitate 3" exhaust lol or at least the tailpipe.
BoostedSUV
I have a tailpipe laying around that maybe able to be used. The top of the bend over rear axel has a rust hole but what I remember the rest looks pretty good. As long as my parents didn't chuck it after I moved out you can have it for shipping. Don't know how soon I'd be able to get it though.
Throws
Might even be worth it just to have someone make up a new~er tail. I'd hate to get a new muffler and have to bolt it to my POS one.
-P
atkonkler
Is this your bush?
theres a kit made by dynomax 17383 is the number! says its compatible with our trucks if its a typhoon its cat back! Where did you find that icon pic its ****ing awsome dude!
Throws
Holy crap! You know how many people I asked about a stock kit and was told that nothing existed? Awesome! Many thanks!
-P
-P
There's a Post by DaveP regarding this subject. Even has the dynomax replacement listed. I thought I linked to it in my last post. Looks like I didn't, though.
Throws
No problem. Good thing is the whole setup is only $125 or so on Amazon. Not bad.
-P
Throws
Click where it says "view all applications...". You'll see that its for a 4 door. The only thing Dynomax offers is a replacement muffler 17748 single in single out 2.5" Super Turbo, exactly like the original.
http://www.syty.net/forums/showthread.php?t=74859&highlight=dynomax
OK... So time to follow up on this again:
Other than the 17748, will the #31928 flange/midpipe work? How about the tailipipe? Any good ideas for a 2.5 to 3" tailpipe?
-P
MoJo
A Syclone ZR9 had a dual reverse flow (oval) muffler and tail pipe assembly. The dual tailpipe / muffler assembly was on the passenger side and the tailpipes were straight and exited the under-body at the rear bumper and not behind the RR tire as the tailpipe did on the LB4-Z Blazer and pick-ups. The Syclone had a dual tailpipe and dual muffler assembly which was a welded one piece assembly from the catalytic converter back, .
The Typhoon Z79 had a standard reverse flow muffler and single tail pipe. The muffler-tailpipe assembly was welded one piece from the catalytic converter back. The Typhoon muffler and tailpipe was not serviced separately. The same 3-way catalytic converter was used on all models from 1988-1993..
All the Syclone and Typhoon exhaust system parts has been discontinued by GM. To install a new system on those models and keep it original in appearance, it must be custom made.
Walker makes a excellent bolt on exhaust system that fit Syclones and Typhoons from the catalytic converter back. They are not a duplicate of the OEM exhaust system for the Syclones and Typhoons but the system works great with no leaks, the system bolts on in one hour with a 18" lift floor jack using hand tools and you do not need to weld anything. . The most difficult part of the job is removing your old system. Walker also makes a complete exhaust system for the Chevrolet S10 and GMC T10 models including the Y-pipe. New metric and SAE bolts are available from Bolt Depot ( www.boltdepot.com ) and there is no minimum order.
Throws
I found the muffler, a Dynomax Super turbo, but can't seemingly verify the "mid-pipe" (31928?).
DaveP had some fantastic pics of the part leaving the rear of the muffler, it comes out as a 2.5" then anfter an inch, goes into 3". Odd, but seems like that was the party line at PAS.
-P
Throws
I've put a call out to Sportmachines for a ATR "take off". I figure the cost to have some exhaust shop weld a 3" rear section would put me into a new stainless one.
-P
tphilpot
This may be a candidate for the Vault.
The Dynomax kit 17383 works great. No welding, just hand tools. There are a couple of small tricks which I will share. You need a grinder so you can remove the hooks from the trail pipe. You then need to take 1.5 inches off the cat to muffler pipe.
The hangers are the tricky part. I found the best luck in a couple of universal ones from O'reilly. I removed the factory hangers (and kept them of course) and just bolted the universal hangers into the holes there. I had to shorten the muffler hanger with the grinder which of course was a 2 minute job.
I get it all hung loosely before tightening any thing. Be careful of the tailpipe and the cladding while you are moving things around.
Looks great, sounds great. Suits a stock truck.
