Stock exhaust/muffler?
aasltmike
Took some pics of the muffler under my Ty earlier tonight and wondering if anyone can tell me if it is the stock muffler from the factory? The lady I bought my Ty off of didn't appear to do too much to the truck while she owned it. Judging from the rust at some of the edges, I'm betting it is the stock set-up. Thanks.
http://i861.photobucket.com/albums/ab180/aasltmike/IMG_0072.jpg
http://i861.photobucket.com/albums/ab180/aasltmike/IMG_0073.jpg
http://i861.photobucket.com/albums/ab180/aasltmike/IMG_0074.jpg
aasltmike
Re: Stock exhaust/muffler?
OK, that would explain the exhaust note that I get out of it. Once it decides to go south and need replacing, any suggestions as to what Flowmaster to put on it to keep more or less the same rumble it has now?
warmpancakes
chamered exhaust like a flowmaster has fluxuating backpressure meaning the turbo can spool easy then harder then easy the harder, the best exhaust for a turbo car is the least exhaust. The dynomax straight through work the best or any similar muffler
aasltmike
Went to the site and checked...would a Dynomax Ultra Flow Welded be a good one?
gkrcr882
SyTyless......for now!
Magnaflow. I put one on and love it, sounds great and its built solid. Straight thru design without being too loud.
aasltmike
The pic of the stocker above has the dynomax number right on it: 17748. It's only a 2-1/2" inlet/outlet, though.
Wouldn't the Super Turbo stock set-up be a bit more of a mellow sound, though? I'm interested in retaining the deeper note I have now...my research has turned up those for and those against a Flowmaster on a turbo engine. Quite honestly, I'm not out to wring every last ounce of horsepower out of my Ty and I will prolly stay with the Flowmaster unless there are dire consequences for it, i.e. my engine blowing up or grenading something. I like the note I get out of the Flowmaster, and the info I've read leads me to believe I'll lose the note with a flow-thru. One forum (I forget which one, right now) said a flow-thru sounds like a pissed bumblebee and I don't want my truck sounding like that.
Sy643
I picked up a 3 inch stainless with no muffler from sytyperformance when my stock muffler gave out. It looks great, easy to install and gave it a nice deep sound.:2cents:
Chedarbob90
White Trash Racing
I bought mine with a junk cat and straight pipe after that and decided to throw on a magnaflow cat that came with the truck and it changed it quite a bit actually. I can hear the turbo spool better and it has a throatier rumble at idle.
BoostedSUV
I'm running an ATR 3" catback (not available anymore) and personally it sound's better than any flowmaster I've heard. Flowmaster's suck on our trucks and if anything a straight through muffler should be a touch louder and sound better. RPM's kit is the best available exhaust system out there right now but a Borla or Magnflow straight through muffler will sound better and perform better than a flowmaster. :2cents:
BoostedSUV
are you sure that's a stocker? That's a Dynomax Super Turbo muffler... is that what our trucks came with? Just curious, mine already had an ATR catback when I bought it.
kens-syclone
i have no muffler at all . i have the factory cat and 3" piping from there back with no muffler , i sounds ok to me. but then again i bought mine like that.
BoostedSUV
Put your cursor over the pic. Right click>Properties. Look at the address and see who's account that pic is linked to. That's a pic of the bottom of his truck. If he say's it's stock, you can take that to the bank. And besides, look at all the holes in it. It's been under there awhile. Like 18 years.
Isn't Ty0331 Dave's truck? ;)
If purist Dave says it's stock then I believe it's stock. I learned something new today :tup:
Yes, Typhoon came with a single 3" Dynomax Super Turbo mufflers. Syclone had two 2.5" Dynomax Super Turbo mufflers.
Off topic: Thats the exact muffler that came in my Dynomax catback system.
You can get them all day long for ~$50
aasltmike
Sooo whats the verdict?
My verdict is that I believe that I actually have a resonator, not a muffler...it was on the truck when I bought it. The lady I bought the Ty from, IMO, had the Ty just because of the, "Oooooo, neat-o!" factor. She and her son did not really know what they had or how to take care of it. I ordered a Magnaflow muffler and cat from Summit and will have it put in place this weekend.
It's NOT a 3" muffler. It is a 2-1/2" muffler. The tail pipe is 3", and you can clearly see the neck-up in size into the tailpipe out of the muffler outlet in this pic. The inlet pipe is also 2-1/2".
Your right. I had a Typhoon with a stock exhuast for about one day on the road. The exhuast had a ton of holes (and I knew it was the original because I bought the Ty off the original owner) I didn't inspect it all that well. The tail pipe was split and basically fell off the muffler. When I had it replace at an exhaust shope and the rusty system was in a pile, my observation were this is a 3" exhaust (tailpipe) and Ty's come with Dynomax Super Turbo muffler like the Sy do.
