Re: stock FPR psi
Just for a little more input/reference.
I did a quick check of my Fuel pressure with the vac line connected (stock FPR). I was checking it to check for injector leak down, trying to track down something a start up issue. With the engine running it was steady at 38psi. When I switched off it, the pressure steadily crept up to 43psi. and pretty much stayed there for 10 minutes. I expected it to increase a instantly after switching off and then drop down a little more after that due to injector leakage. I was happy though that the pressure stayed up.
