Stock injector chip available soon.
Turbo6
10.20@131.8
I will have an open loop stock injector chip available soon. It will have 2 timing settings and 8 fuel settings with a valet mode. The valet mode also doubles as an emissions mode with closed loop and EGR. They will be sold through Turbotime.us. They should be available in a week or 2. Also I can make all the programs closed loop if you would like!
typhoon92
Re: Stock injector chip available soon.
Is this like the one I have but i have not tried yet? ( 3 bar stock inj closed loop)
This new chip will be for a stock turbo also?
Turbo6
10.20@131.8
Yours has 16 different programs for fuel and low timing only for pump gas. If you want this one for the higher timing I'll send it to you at a good price just pm me.
gmcturbo
Phil, are you willing to make chips for alky and stock injectors and help tune?
Flyin Ryan
hated cuz he drives fords
That's what I was wondering as well..
Turbo6
10.20@131.8
The only good way to do that is to bring the truck to me and put it on the dyno or tune it at the track. You cant do it very well over the internet! Another thing, I dont like using alky for lots of reasons and many wont agree with me but i wont start that on this thread or any other!
danny
will you offer the chip with a choice of 2 or 3 bar map?
SY2455
70's Veteran
Phil, a few dumb Questions.
1. How will it compare to the ultimate chip?
2. How well will it work with the cheap 91 octane gas here in Calif?
3. Is it made for the stock engine or is there a min amount of upgrades that need to be done 1st to run this chip. ( all stock Syclone with the 3" downpipe that was a group purchase a while back so you could remove the puck from the back of the turbo)?
4. If not how much would you charge for a chip so I can change over to my 3" downpipe?
5. Open or close loop? Isn't close loop better?
Turbo6
10.20@131.8
I can make you a 2bar if you would like but 3bar is standard.
Turbo6
10.20@131.8
Similar to the ultimate. Ours is $299 and I'm not sure how much the ultimate costs.
It should be fine on the low timing settings,if not I'll make you a chip with lower timing under boost that will plug right in the place of the other one for $35.
Yes it has 8 different fuel settings under boost so playing with the chip fueling and fuel pressure you can make it work with different combinations of upgrades.
Either way you want it same price! If closed is better or not is up to you and what you are doing with it. Open loop will fix the bad idle most of the time but it has to be richer and closed loop will keep you at 14.7/1 under idle and normal driving.
TheNeek
this is my serious face
Phil,
Just a thought: How about having two programs be exactly the same for normal driving (low timing, normal fuel), but have one be open loop and one closed? Being able to switch between open and closed loop would help diagnose problems I'd imagine not to mention save some of that precious petrol.
I'm sold though.
One other Q. Does open loop mean that I can remove the stock 02 sensor and install a wideband with stand alone monitoring? I've never done a chip before.
Turbo6
10.20@131.8
TheNeek said:
Phil,
I'm sold though.
Yes if you run open loop you can put the wideband in the stock o2 hole. You can also just have a closed loop programs and unplug the stock o2 to make it open loop but that way you dont get any readings off the o2 if you dont have a wideband and it can cause a CE light also.
I can make any of the programs closed loop that you want just add $35 to the base price for the changes you want on your chip.
Turbo6
10.20@131.8
Vsix said:
Is the chip available yet and how much ?
Thanks Jim
Give us a couple more days. You can go ahead and order it from Turbotime for $299. He should be able to ship it by the end of the week.
