Easy math, you can calculate how much fuel you need to support a given amount of horsepower.
Syty - 6 x 28 = ~168lb/hr, at .5 BSFC, that's good for 340hp (give or take), on a truck that made 280 hp. 280/340 = 0.82
LS1 - 8 x 26 = 208lb/hr, at .5 BSFC, that's good for ~420hp, on a car that made 345hp. 345/420 = 0.82
Interesting eh?
Now don't bring up the cars/trucks that make more than the horsepower estimates I have just posted. Those vehicles either run more fuel pressure, or run leaner BSFC's, or both. These are just estimates.
I went to 50s for several reasons, I've gone over it about 100 times now.
Here are my biggest choices for upgraded injectors:
36lb/38lb/42.5lb/50lb
The 36lb blue top injectors had great characteristics, were great injectors, and used to plentiful. They aren't anymore. 36lb Delphi's are a bit more difficult to tune for, plus they only offer a *tad* more fuel.
38s, still difficult to tune for, and don't offer us *that* much more headroom.
42.5lb 009 injectors are very difficult to tune for. I did make some progress with them, but once you start throwing modified motors into the mix, the part throttle/idle calibration needs to be changed so much, so I'd really struggle with each chip version.
50s - very easy to tune for, offer a lot of injector headroom, easy to modify each calibration for different versions (heads/cam versus stock motor buildups). Also, if a person does 50s on the stock motor with bigger turbo build, when/if they go to a built motor with heads & cam, it would only require an eprom upgrade to a different program. The Buick guys are heading this way also, many very stock guys are going straight to 50s, then changing the chip cal once they modify the car.
