Stock Intake manifold CFM
Has anyone ever put the stock upper & lower on a test bench to measure its air flow (or even just the lower)
badnewz
Re: Stock Intake manifold CFM
I don't want to put the cart before the horse, but I am pretty confident I'll run an 8 or real close to it with my stock upper and lower intake. I know my motor is making over a 1000hp, and I still have a lot of room to turn it up. When I get some EGT data on each cylinder I will post it, should find out which one is the leanest.
Probably not the answer you were looking for but I will have some data. that might help, in the next few weeks
Mike B
Good Luck with running 8's I hope to see you and your truck at the Nats this year.
I would be interested in seeing that data as well.
Wikid 1
200+ lbs of puppy!
exactly HOW stock are we talkin here? vortech heads? stock casting, loads of port work? or fully, they way PAS casted them, STOCK?
Windedv6
Ty n 10s
Mike
If you can get EGT readings on each cylinder...that will tell a story that been missing forever on these intakes. That would be a great thing!
Good luck on your times...you can do it!
John
badnewz
Well they look totally stock form the outside:) The stuff has been reworked for sure.
Chevy 23* heads
Mike B
