Stock manifolds with vortec ?
MIXEDBREED
Might be a stupid question but will the stock manifolds bolt onto vortec heads, only reason I am asking is because the vortecs I have dont seem to want to line up with my stock manifold mounting holes. Maybe i am doing somehting wrong but not sure. I did a search but didn't see anything about them not working.
CC801
Re: Stock manifolds with vortec ?
They fit just fine. You will probably need a tool to spread the manifold to get it to line up.
MIXEDBREED
Could that cause the manifolds to break? Not sure what tool to use for that but I will def look into it. Thank you.
Icarus-54
Donating Old Member
Your manifolds are warped,put them in the oven and use a spreader
fivetodrive
CRISPY
I haven't had to use a spreader but we have succesfully used the oven trick a few times. Get them as hot as your oven goes for at least 20 min and then put the two outside bolts in quick! It helps to have a helper and a good set of oven mits / gloves.
If the motor is in the truck take out the fenderwells!
MIXEDBREED
Thanks for the help. Sucks that that it happened. I just took them off the old block and within 5 min they would not bolt back on. I will try the oven today when I get home though
Slyclone
Well-known member
This is what I used. I got 2- this was never opened or used. If you are interested make offer.
MIXEDBREED
Thanks to all that helped, I got the tools from autozone but it only fit between one side on the manifold, the left side is to close together to fit the tool in. Instead i used the oven idea and that worked for me. Those damn things came out hot lol I had to waer gloves and oven mits.
fivetodrive
CRISPY
I guess I should have said gloves and mitts!!! Glad to hear another oven trick worked!!!
MIXEDBREED
Barbeque works well also, ours will get to 600deg!
I put it on self clean and the sob got hot, not sure how much but the oven dial goes to 550 and I am pretty sure the self clean gets a little hotter. Either way it does work. Never put back on stock iron manifolds before, I always used steel aftermarket stuff on all the ls engine platforms so never had this issue, but like everything else with a syclone I learn something new every time I go to work on the truck.
THEMADTYPH00N
All it took for me was a few minutes with a heat gun. Didn't even need an oven or grill.
