stock max boost question
IGottaSy
I am just wondering. What is the number one reason these trucks were built to run 14.5psi boost in stock form?? Given the injectors are marginal but adding fuel pressure would allow for more. The only thing that comes to mind is that 2 bar map sensor. Excuse the trivia.
randy merritt
Re: stock max boost question
I would assume the two bar map sensor myself, but I don't really know. 14.7 psi would max out a 2 bar sensor.
Quickstop [UK]
Combating adversyty.
There's probably not one single component-based reason, more that the power generated goes up in cost considerably. More boost = more IAT = more fuel, more injector needed, more ECM/larger tables and charts needed, more IC, more programming etc.
The law of diminishing returns and a cost point and someone made the call to stick below that point. That boost sensor probably delineated it as easily as anything else.
:2cents:
Hard to know without a PAS designer commenting.
Ross L
My "guess" is at the time around 14-16 is about the max "safe" boost allowed on 93 octane.
