HighPerformanceTrucks
Lift & Shift Specialist
While I had the front differential out for refreshing, I decided it would be a good time to do the motor mounts as well. I will be installing the solid mounts.
My Sy has 117,000 or so miles and the rubber mounts are cracked and distorted.
I had to use a dremel to grind enough bulging rubber away to access the bolt heads!
The problem I'm having is a don't see any way to get access to the front pad bolts, especially on the driver's side. I can't even seem them w/o a mirror.
I don't have an engine hoist.
Any suggestions would be very helpful.
