Stock Timing Chain P/N?? Single Roller
Alright, freshening up an old SYTY motor to get my truck back on the road. Built motor should be done by spring to take it's place.
I want to replace the timing chain since the motor has high miles but am having the heck of a time finding the correct chain. First, the timing chain I pulled off was a true single roller. Everything I find shows the factory chain is a link chain, not a roller.
Did your SYTY have a true single roller or link chain from the factory?
On all the threads I looked through, everyone suggests going double roller. I don't want to spend much money on it and yes, the built motor is getting a double roller. I searched the site extensively looking for a single roller part number, checked summit, Advance, PM'd Hood with no response, looked for PN's on SyTyAuthority. I unless I want to buy a full set I can't seem to find what I need.
Will this work? http://www.summitracing.com/parts/SLP-KT-3499S/ Picture is wrong but says it is a 'roller', 3 bolt attachment. Cheap enough that I don't care that it is a full set.
MoJo
Re: Stock Timing Chain P/N?? Single Roller
I don't recommend anything I have not used personally. I used GM-12371043 single roller timing set in my 1991 4.3L V6 and it is a excellent set and runs quiet. You don't need a double roller. The double roller timing set is a myth that was started by Ford Motor Company many years ago.
GM 12371043 kit includes two new thrust plates (one for SB V8 and one for 4.3L V6 engines) , two thrust plate bolts, single roller chain, cam sprocket and crank sprocket ....$56.25 MSRP + sales tax. This GM timing chain and sprockets is Melling 3-202SA..
This timing set kit is available at any Chevrolet dealership, and it will probably be a special order. It is cheaper from a Chevrolet dealership than from Summit, Jegs or GM Part Direct after you add shipping cost.
Throws
I don't recommend anything I have not used personally. I used GM-12371043 single roller timing set in my 1991 4.3L V6 and it is a excellent set and runs quiet. You don't need a double roller. The double roller timing set is a myth that was started by Ford Motor Company many years ago...
Sorry to bring up an old topic, but I'm curious... how would double roller timing chains be less advantageous than a single chain? Getting ready to do a bit of a refresh, and I'm genuinely curious.
-P
Syclone22
-P
Go with the dual rollers timing chain it,s better than a single !!! :tup:
MoJo
A double roller chain can be compared to wearing two parachutes.
The double roller gives a extra measure of security but the wear factor using a double roller chain is the same when using a single roller chain. You have two rollers wearing instead of one. The reason the factory does not use a double roller chains is cost and noise. GM has grappled with the timing set noise problem for at least years 45 years. GM has always used a Morse chain because it was quiet but they thought it was not quiet enough. Therefore, in 1967, GM experimented with a aluminum cam sprocket to reduce rotational mass, which had nylon gears to reduce noise. A design which was a total failure. Today cars have knock sensors and a quiet Morse chain is still necessary to prevent ignition retard from a false knock. GM moved the knock sensors around on the engines to find a location that will not pick up timing chain noise. The most quiet location for the knock sensor is in the rear of the block in the bell housing flange under the distributor. That location is as far from the timing chain as possible. .
A single roller chain has less rotational mass, it is more silent than a double roller set, and is more than adequate for street driven engines and amateur competition. On the other hand, a double roller chain is needed with bone crushing valve spring pressure (over 350 lb. open)for more strength. Double roller chains ar keyed to allow the valve timing to be advanced or and retarded and therefore is a better choice for professional competition engines.
Since my engine has 300 lb. open valve spring pressure after break in, and rather than risk timing chain noise and unpredictable ignition retard, I used a GM single roller timing set.
The Corvettes in the 24 hours of Lemans use single roller timing sets...go figure?
Throws
The good 'ol Katech C5R timing chain. Almost got one for my GTO, but wanted new sprockets included so I went with Protech.
Ok, now, for a budget refresh <$30 what would you go with? I'm just trying to keep my mill with 150k miles on it together. :tup:
-P
Syclone22
I love my Jesel external timing belt conversion this has
a open belt for adjusting the camshaft advance or retard
it has no noise what so ever but is strictly off road use !! ;)
