Stock timing cover and double roller chains.
Throws
Why does Summit say for the Cloyes 9-1145:
4 degrees of crankshaft advance/retard reflects 2 degrees of camshaft advance/retard. For factory roller camshaft motors. Will not fit behind stock timing cover.
Will it or won't it? I've heard the Edelbrock requires grinding the block a titch (Tooky posted about this...), but no one has said boo about our timing covers being too shallow.
Anyone?
-P
MoJo
Re: Stock timing cover and double roller chains.
Summit is referring to the plastic timing covers used on the balance shaft engines. That statement is more accurate as mentioned in the notes for the Cloyes 9-3145 timing set.
sytyguy
Moderated User
Ditto. For our timing covers there are no clearance issues. At least none that I've ever encountered and I've used several Cloyes sets and countless Edelbrock ones.
Throws
Thanks! That's the confirmation I was looking for.
-P
