Stock turbo pull till 5500rpm?
02Vortech
300whp turbo blazer-
hey im turbochargin my blazer and looking for manifolds/turbo- i like the idea of the stock turbo but i was wondering does it pull hard uptop or does it fall off- once i get a good valvetrain in i will be running 5500rpms- My main thing is a topend- i am spraying the truck right now and still have no topend- thanks
BTW if your selling a turbo or your manifolds let me know
Loeryder
Re: Stock turbo pull till 5500rpm?
The stock turbos are undersized for a 4.3 so once you are above 17PSI they are out of their efficiency range and generate more heat than horsepower.
Since you are goin custom your best bet would be to get the SyTy manifolds and an aftermarket turbo, like the PTE setup.
www.turbotime.us can hook you up.
SY756
I agree with Jason 100% on that. You would be better off with Sy\Ty manifolds and getting a larger PTE setup. If you're really wanting top end go with a PTE 60 or bigger. Just depends on what your plan is.
VermontTy
Support Our Troops
Are you putting SyTy exhaust manifolds and a turbo on your stock CPI 4.3, or are you going to be adding the SyTy intake manifold, injectors, ECM, etc? The reason I ask is that you aren't going to get a whole hell of a lot of fuel out of your stock CPI setup. With your stock "high compression" motor, you're going to run give or take 8 lbs boost before you start knocking like a bastard and blow the thing apart. You don't have the bottom end, or the fueling to push the stock turbo to its inefficiency.....
summerwolf
02 blazer 5 spd
well, on 02 and up (actually 98+ for the most part) they don't have CPI
you can use your stock intake manifold, fuel it using an FMU (like the supercharger kits) and run about 6-8 lbs.....
if you want to get all you can run an edelbrock 2114 manifold thats been tapped and had bungs welded for individual fuel injectors.
With a good tune though 6-8 lbs of psi is a drastic improvement over what we had....and our compression is fairly turbo friendly, stock bottom end on 8 lbs will hold up forever
Robert Lone
MUTANT
^^^^^^^^^^^1st post! Welcome!:tup:
summerwolf
02 blazer 5 spd
thanks...I came here to buy manifolds and stuff and might have just found myself one hell of a deal....I'm planning on doing this to my 02 blazer 5 spd myself so I've been lurking for a while....figured I needed an account since parts came across and here I am....
Robert Lone
MUTANT
I you ever need help w/ the manual behind the Sy engine, I'll try. :tup:
summerwolf
02 blazer 5 spd
its not a sy engine....its an 02 vortec engine, vortec heads (P/P bigger intake exhaust valves 1.6 rollers) and I'm bolting up the sy manifolds and xover...stock turbo, cai, basically as much stock stuff as I can use and custom do what I need to.....custom downpipe, and intercooler behind the grille....
the nv3500 isn't going to last, it doesn't like the spray I'm pushing now....even with the dual friction clutch...so after it blows modifying the block to run a t56...
