I am having issues with my Typhoon and an overboost issue. Truck is stock and I have driven the truck 7k miles DD with no issues. Recently I began having an issue with the truck blowing off the TB coupler. I replaced the middle bolt on the upper intercooler because it was missing and switched to 4" T-bolt clamps.
The coupler stopped popping off, but began overboosting to 20+ psi. Truck is all stock and was running great until the coupler started popping off. Before it held at solid 15 PSI of boost and felt very strong. I did a datalog, and it appears the wastegate is functioning as it should. the truck seems to be building boost much faster than normal.
What could be the cause of this? I don't believe anyone has messed with the wastegate rod, nor is the cat gutted. The Datalog shows I am having knock issues, as well as codes 35 and 44.
Thanks in advance!
Thanks in advance!
